    f750's Avatar
    Lives in herne bay, United Kingdom. Last Activity: 21-11-2022 Has been a member for 9-10 years. Has a total post count of 13. Received thanks 1 times, giving thanks to others 0 times.
    Hi does anyone know how to change the post processor from tap file to nc file in Fusion 360. Watched a few youtube videos and it is not clear.
    Cheers Tony
    The NC file is the file which contains the gcode. I'm fairly sure it can have a few different extensions but contain the same information. So it could be myshape.nc myshape.tap myshape.txt and I'm pretty sure Mach3 will open it and read it as they are all basically text files.
    But before changing the extension what for a second opinion (!) as I haven't dabbled at that level for many years.
    Possibly you are asking a different question ?
    f750's Avatar
    Hi thank for the reply, I have been to change the file in Fusion 360 preferences something called External editor.
    Lives in East Lothian, United Kingdom. Current Activity: Viewing Forum Superstar, has done so much to help others, they deserve a medal. Has been a member for 9-10 years. Has a total post count of 2,910. Received thanks 360 times, giving thanks to others 8 times.
    I thought .nc was the default output, but then it's probably what is set in the post processors I happen to use.
    If the post processor file you're using is set to tap, and everything else is ok, open the post processor.
    Either from within F360 - manufacture -> 'manage' drop down menu -> Post Library, then in the new window right-click on the post, and select Edit, or alternatively find).
    or in the local storage folder - C:\Users\<user>\AppData\Roaming\Autodesk\Fusion 360 CAM\Posts
    You need to change the extension = "nc"; variable (it's near the top).
    Then save the file, and it should be updated next time you post code in F360.
    Quote Originally Posted by f750 View Post
    Post processor editing is done an external editor.
    If you're on windows, I would strongly recommend downloading and installing Notepad++, as it won't screw up text formatting like the default Windows Notepad generally does.
    f750's Avatar
    Managed to resolve it - had to edit the file in the following location C:\Users\<user>\AppData\Local\Autodesk\Autodesk Fusion 360\CAM\cache\posts
    Thanks for your help
  1. Adding a post processor
    By DaveC in forum Fusion 360
    Last Post: 17-08-2020, 09:53 AM
  2. Post processor
    By DaveC in forum Tool & Tooling Technology
    Last Post: 03-08-2019, 09:43 AM
  3. Post Processor for Heidenhain tnc 145???
    By jackpat in forum CAD & CAM Software
    Last Post: 04-07-2016, 10:17 PM
  4. Help with Post Processor
    By superpot in forum CAD & CAM Software
    Last Post: 20-11-2013, 11:23 AM
  5. Post processor Sei
    By 2006Nobull in forum Machine Discussion
    Last Post: 04-08-2011, 12:58 PM
