    Cheers Jazz,
    Found plugin and installed and all is working , only slight problem is that when it goes back to home its out by a couple of mm, did a cut on a small file that uses 4 passes and it looked fine , no missed steps as far as i can see not like before when it went out by miles. Anyway going to see how it goes before i decide if i am going to change anything so
    thanks for all the advice.
    Dave
    Quote Originally Posted by mrmacca View Post
    Cheers Jazz,
    Dave
    Hi Jazz ,
    Been a few months and still having problems, so will purchase controller you mentioned the AXBB-E controller ......Is that all that I need to purchase.
    Dave
    Hi Jazz ,
    Dave
    To use the AXBB-E you will need 5Vdc and 24Vdc in the control box so you might need a PSU depending on what you have already. You can use 12Vdc in place of 24Vdc if don't have it, Some people use an old PC power supply that has both 5V and 12Vdc outputs.
    Other than that all you need is an Ethernet cross-over Cable if running directly to PC or a standard Ethernet cable if running through a network hub or Switch.
    Email: [email protected]
    Web site: www.jazzcnc.co.uk
    Cheers for the quick reply, will let you know how i get on.
    I take it you have looked at Dean's website Web site: www.jazzcnc.co.uk
  1. Z axis out by 2mm mach3 or fusion360 problem?
    By Richardtweed in forum Machine Discussion
    Last Post: 01-05-2022, 08:41 PM
  2. Mach3 lathe spindle pulleys problem
    By John11668 in forum Artsoft Mach (3 & 4)
    Last Post: 30-01-2021, 03:04 PM
  3. Small Mach3 Problem
    By needleworks in forum General Discussion
    Last Post: 11-05-2020, 10:46 AM
  4. Mach3 & V-Carve Problem
    By Ricardoco in forum Computer Software
    Last Post: 31-05-2013, 12:53 PM
  5. Mach3 small problem
    By dudz in forum Artsoft Mach (3 & 4)
    Last Post: 15-11-2012, 05:56 PM
