    dazp - when you say "AC" bearings, what do you mean by that - are you referring to the seals? To minimise the backlash you presumably used back to back or double row bearings?
    Angular Contact.
    I made my own bearing blocks (23mm thick with 2mm wide internal ridge) from 1 inch alloy stock.
    Fitted 2x 7201-B-2RS in each for use on 1605 screws. Back to Back.
    Adjusted preload on DFU with bits of 0.01mm thick alu foil between the nuts.
    These are the screws and seller I used on x,y,z
    https://www.ebay.co.uk/itm/263083205...4AAOSwal5YEjRE
    (I think I got a slightly shorter 700mm one for z)
    Haven't tried their 2005 ones. My 25 mill was fine with all 1605.
  1. mill with no quill conversion
    By mcmental76 in forum Milling Machines, Builds & Conversions
    Last Post: 21-08-2021, 06:00 AM
  2. CNC conversion AMAT25LV AMAT30LV WM18 advice needed for total novice
    By Hulksmash in forum Milling Machines, Builds & Conversions
    Last Post: 18-12-2018, 12:31 PM
  3. CONVERSION: Sx3 mill conversion
    By dazza in forum Conversion Build Logs
    Last Post: 29-04-2014, 10:23 AM
  4. Mill conversion to cnc
    By wolsey in forum General Discussion
    Last Post: 15-08-2011, 11:07 PM
  5. Help with drill-Mill conversion
    By Ross77 in forum Milling Machines, Builds & Conversions
    Last Post: 02-04-2010, 10:25 AM
