23-11-2022 #22
Actually John, thank you. It looks a nice piece of kit.
23-11-2022 #23
Just got mine today. 12 days from ordering.
Looks good. Can't test it out for a little while yet though.
24-11-2022 #24
Have you folks seen the Craty CNC software for Mach3 & UCCNC. I have had it for a while and it is well worth a look.
In particular the compensation for eccentricity in the probe and the point cloud programming which I have used to good effect.
Quite inexpensive as I recall. I have no connection, other than a satisfied customer.
http://www.craftycnc.com/
Thanks! Looks very interesting, I think I'll download the trial version and give it a go.
24-11-2022 #26
John - You may have to search through his youtube vids. Google what you require as youtube index does not always find them all.
25-11-2022 #27
Are you aware that these probes have adjustment for eliminating eccentricity (as most do)? In this case, they have 4 radial grub screws that can be used to shift the tip in X and Y. You need a dial gauge (DTI) with light tip force, then adjust the screws until there is no runout / eccentricity when you rotate the probe. You should only need to do this if (when!) you have a crash and need to replace or straighten the tip although a periodic check is sensible.
The Renishaw probes use a different system, with a ball bearing pivot under the base and 4 axial screws but to the same effect.
The trigger point for most of these probes varies slightly according to the orientation of the probe, due to the 3 internal pivots. So it's a good idea to orientate the probe in the same direction each time you use it, for consistency. That's a different issue to eccentricity.
25-11-2022 #28
Have owned many probes in my lifetime. If this one remains constant over time I will be overjoyed.
(Incidentally do you check the runout of your collet chuck before setting the probe. That can be an eye opener in itself!!)
I have spindle jigs to maintain orientation ranging from scratched lines to mechanical dowel slots.
Looking forward to exercising the new one.
Hope the experience sharing will will continue.
25-11-2022 #29
I don't use a collet chuck to mount and remount my Renishaw probe on the mill - it came with its own pukka ISO40 holder. For my lathe, this DIYO probe will be used for tool touchoff, mounted in a fixture, so eccentricity won't be an issue - it just needs to stay fixed in position. Perhaps when I've completed it I will post pics / vid!
There are currently 16 users browsing this thread. (0 members and 16 guests)
3d touch probe
By johngoodrich in forum Tool & Tooling TechnologyReplies: 23Last Post: 24-10-2021, 06:14 PM -
Any ideas or thoughts on making a edge finder come touch off tool
By suesi34e in forum Electronic Project BuildingReplies: 26Last Post: 01-01-2020, 06:28 AM -
Edge Probe + tool length probe on same input
By Noplace in forum General ElectronicsReplies: 1Last Post: 18-06-2016, 11:12 AM -
Touch probe stylus - where to buy?
By Mad Professor in forum Marketplace DiscussionReplies: 3Last Post: 05-08-2013, 07:07 PM -
Touch Probe
By luke11cnc in forum Probing, Digitizing & ScaningReplies: 28Last Post: 31-01-2012, 01:16 AM
