Page 3 of 3 FirstFirst 123
  1. #21
    Quote Originally Posted by Leadhead View Post
    Relieved to say that it turned up today.
    Phew! Was afraid I'd persuaded you to buy a pup!
  2. #22
    Actually John, thank you. It looks a nice piece of kit.
  3. #23
    Just got mine today. 12 days from ordering.
    Looks good. Can't test it out for a little while yet though.
  4. #24
    Have you folks seen the Craty CNC software for Mach3 & UCCNC. I have had it for a while and it is well worth a look.
    In particular the compensation for eccentricity in the probe and the point cloud programming which I have used to good effect.
    Quite inexpensive as I recall. I have no connection, other than a satisfied customer.
  5. #25
    http://www.craftycnc.com/
    Thanks! Looks very interesting, I think I'll download the trial version and give it a go.
  6. #26
    John - You may have to search through his youtube vids. Google what you require as youtube index does not always find them all.
  7. #27
    In particular the compensation for eccentricity in the probe....
    Are you aware that these probes have adjustment for eliminating eccentricity (as most do)? In this case, they have 4 radial grub screws that can be used to shift the tip in X and Y. You need a dial gauge (DTI) with light tip force, then adjust the screws until there is no runout / eccentricity when you rotate the probe. You should only need to do this if (when!) you have a crash and need to replace or straighten the tip although a periodic check is sensible.
    The Renishaw probes use a different system, with a ball bearing pivot under the base and 4 axial screws but to the same effect.
    The trigger point for most of these probes varies slightly according to the orientation of the probe, due to the 3 internal pivots. So it's a good idea to orientate the probe in the same direction each time you use it, for consistency. That's a different issue to eccentricity.
  8. #28
    Have owned many probes in my lifetime. If this one remains constant over time I will be overjoyed.
    (Incidentally do you check the runout of your collet chuck before setting the probe. That can be an eye opener in itself!!)
    I have spindle jigs to maintain orientation ranging from scratched lines to mechanical dowel slots.
    Looking forward to exercising the new one.
    Hope the experience sharing will will continue.
  9. #29
    I don't use a collet chuck to mount and remount my Renishaw probe on the mill - it came with its own pukka ISO40 holder. For my lathe, this DIYO probe will be used for tool touchoff, mounted in a fixture, so eccentricity won't be an issue - it just needs to stay fixed in position. Perhaps when I've completed it I will post pics / vid!
  1. 3d touch probe
    By johngoodrich in forum Tool & Tooling Technology
    Last Post: 24-10-2021, 06:14 PM
  2. Any ideas or thoughts on making a edge finder come touch off tool
    By suesi34e in forum Electronic Project Building
    Last Post: 01-01-2020, 06:28 AM
  3. Edge Probe + tool length probe on same input
    By Noplace in forum General Electronics
    Last Post: 18-06-2016, 11:12 AM
  4. Touch probe stylus - where to buy?
    By Mad Professor in forum Marketplace Discussion
    Last Post: 05-08-2013, 07:07 PM
  5. Touch Probe
    By luke11cnc in forum Probing, Digitizing & Scaning
    Last Post: 31-01-2012, 01:16 AM
