Thread: Spindle Control with PWM PSU
28-04-2023 #1
Hello Everyone this is my first post.
I have received from Aliexpress my 800w Spindle with the respective PSU PWM controller with 4.7 k pot (https://www.aliexpress.com/item/1005001551850219.html the one i have is similar to this). Spindle is DC 110V rated. I want to control this with MACH3 breakout red card.
I cant find any trustable info on how to wire the card to the controller with the purpose of controlling the spindle with MACH3 Breakout card (bit sensor one; aka red pcb);
Additionally: What does the pin exciter does?
Thanks in advance.
The excitation pins are to supply the field winding of a wound field motor. If your motor is a permanent magnet type you can ignore these.
In principle you control this from Mach3 by smoothing the PWM output (unless the card already does that) to get a variable voltage and feeding it to the terminal to which the slider of the pot would be connected to, also connecting the GND connection of the breakout card to the negative terminal of the pot. Speed controller usually use a 0-10v signal and yours would hopefully be similar but the documentation is silent on this.
HOWEVER!!!
A key point is whether the unit is fully isolated from the mains. The photo of the PCB does not show a convincing isolation transformer. The "ground" of the unit may be live when the unit is operating, in which case unless your breakout card has isolation you will get a "loud brown smell" when you connect the mains to the controller and the breakout card and/or the controller may be destroyed. If you're lucky you may survive as long as you're not touching the metalwork.
So it is important to establish if the control voltage input is isolated, or if the breakout card has isolation. If not isolator circuits are available, or are easily built if you are comfortable with electronics.
Was this any use? Was it even read?
Mach 3 - Spindle Control
By myles.merry in forum Artsoft Mach (3 & 4)Replies: 3Last Post: 26-05-2019, 11:13 PM -
Bob for spindle control
By Duffman in forum General DiscussionReplies: 8Last Post: 29-12-2016, 02:14 PM -
DIYCNC C4 Spindle Control
By padski in forum Control Hardware & SystemsReplies: 2Last Post: 12-12-2016, 01:42 PM -
Help with spindle control
By wizzy in forum Spindles & Drive MotorsReplies: 4Last Post: 12-02-2011, 12:51 AM -
CNC spindle control VFD problem
By djc in forum Motor Drivers & ControllersReplies: 1Last Post: 13-09-2009, 09:26 PM
