    Just wondering what options people use for installing linear guide rails. So far I have seen the following.
    1. use taught piano wire and shims ?
    2. Try and source a 10' engineers straight edge ?
    Any other options available ?
    that doesnt sound like fun
    if your using profile rails im guessing the easyest way is to use a DTI guage
    for my X axis rails that were mounted to the sides of my machine (80x120 aluminium slotted extrusion and already pretty straight) i fitted one linear bearing and a DTI on a magnetic stand and concentraited on getting the rails parrallel to the surface my bed would be fitted to, mine is only a short machine though (700mm) if i was making a much bigger machine id consider mounting my rails on the horisontal plane if i could and use epoxy
    i cant remember exactly what its called now but there is a special epoxy that is thin and slow to set so if you make two channels where your rails are going to be fitted and another channel to join the two together when you pore the epoxy in, it will level to perfection (in therory) you will have to do some research on this though, im not sure anyone on this fourm has used this method.
    the problem with a large machine and fine precision is you only have to stub your toe on it and it will go out of true unless its very heavy or bolted to the floor or both :lol:
    EDIT: oops... i didnt realise... you have asked a similar question elswhere and got similar answers
    This post was to cover the detailed aspect of installing the linear guide rails on an 8' * 4' machine, where as the other was more to do with machine frame construction. I have thought about using aluminium, but I don't think the slot and the linear deviation of the profile is accurate enough.
  4. Auto-collimator or laser Interferomter are options, but it all depends just how accurate you want to go.
    No point going for guides in the accuracy of tenths over their length, when the spindle flexes a couple thou under any kind of load.
    Also, unless you get the base heat-treated/stress relieved after welding, it'll gradually flex as the weld induced stresses gradually relief themselves over the next few years, throwing your original accuracy out.
    That's a bummer. What do most home builders do, do they not use steel ?
    Quote Originally Posted by flanagaj View Post
    Most attach one rail with a couple of bolts (this is the reference) then assemble the gantry without the ballscrews/drive attached. Push the gantry back and fourth by hand several times so that the second rail is automatically pulled parallel to the first. Put one bolt in the second rail... move gantry back and fourth, add another bolt ... repeat. Then just check there's no tight spots at the end. This is of course not the best way to do it, but it works.
    For Y and Z you can do the same. Alternatively as the rails are closer you can attach a DTI to one rail, as Mark suggests, and indicate off the reference surface (there's sometimes an arrow to show which - check out the Hiwin linear rail guide). Look at how much it varies and tap it into place.
    Before mounting the first rail you could just put one bolt in, then attach DTI to one bearing block and indicate off the frame to get it parallel to the frame.
    Edit: This may interest you if you've not already found it:
    http://www.cnczone.com/forums/mechan...nterlines.html
    Ok. I am happy with that for getting the rails parallel to one another, but what about the alignment of the first rail. For example, how do most people get the rail level across it's full length making sure there are no high or low spots and ensuring the rail is linear rather than like a piece of spaghetti ?
    When you're drilling the holes to tap for the rails start with a spot drill the right size to make sure they are in the right place. Could perhaps machine some steel bar with a point on the end and harden it, like a center punch, but the same size as the hole in the rail. Use it to mark then drill the holes one at a time. With an M6 bolt in the hole in a profile rail you get about 0.5mm clearance (from memory) so if it's more than that off you would have to start machining the bolt heads down... bad.
    The simple answer is, I'm pretty sure, that most people (myself included) don't bother. They rely on the aluminium extrusion or steel being flat enough to start with. Aluminium extrusion is much closer than steel but obviously not perfect.
    You could scrape the steel surfaces that the rail will mount on (after the frame is bolted down and has 'settled')...that would be ideal but I bet it takes forever. As you mentioned in the first post a taught wire plus optical magnification (with weights to tension and put them in bucket of water / oil to stop them swinging) can act as a straight edge to align from. This enables you to take out any bends is the rail, which there will be, but I'm thinking removing twist is going to harder to achieve?
  9. Quote Originally Posted by flanagaj View Post
    Without having access to (very) expensive measuring equipment, a big straight edge and Mk.1 Eyeball.
    A lot of people don't require a great deal of accuracy on such a large machine. For woodwork, accuracy to a few thou is good enough, and a more typical use for that size in metal is a plasma table, where accuracy to 0.25mm would be acceptable.
    You need to consider what exactly you want to machine, and what kind of tolerance would be acceptable. It's all very well aiming to build a very accurate machine, but will you need the accuracy, and will it be worth the additional cost?
  1. FOR SALE: SBR25-2000mm linear guide round rails
    By Jonathan in forum Items For Sale
    Last Post: 10-10-2014, 05:30 AM
  2. NEW MEMBER: Hi,Friend,I'm a B2C seller from China for ballscrew,linear guide,linear shaft etc.
    By yvesleeok in forum New Member Introductions
    Last Post: 10-08-2013, 11:15 AM
  3. FOR SALE: HIWIN & THK guide blocks and rails
    By vigen20 in forum Items For Sale
    Last Post: 27-02-2013, 10:37 AM
  4. FOR SALE: Minebea psu and linear rails
    By Iwant1 in forum Items For Sale
    Last Post: 15-07-2012, 10:55 PM
  5. Replies: 0
    Last Post: 04-12-2011, 03:23 PM
