10-05-2012 #1
Hi I am putting my Multicutter 8000 router up for sale, the machine is based in Stirling, Scotland and can be seen working. I can assist with disassembly and loading and spend as much time as you need showing you the workings off the machine, how to repair and fault diagnose the whole machine if desired.
Here are the specs,
Rack and pinion X and Y, ballscrew Z fitted with Bosch 1400W router.
Westamp servo motors on the X and Y controlled by Granite device servo drives. Z axis is a stepper and motion control stepper driver.
Pc, Dell optiplex loaded with Mach3, license does not come with the machine as I need it for another router.
I have built a steel table to hold a standard sheet of plywood this can be skimmed with the router and I will include the skimming bit in the sale.
The good thing about this machine is it size and its customization potential, it would make a good conversion to 5 axis if you were up for the challenge.
Price £4000
PM me for my mobile and Email.
Gavin
Photos and vids to follow..
12-05-2012 #2
hi can you tell me when the pics and vids are going on here
12-05-2012 #3
I remember this Did you buy it from Ireland and ask about it on the CNCZONE before buying.? Good few years ago thou.?
13-05-2012 #4hi can you tell me when the pics and vids are going on here
Here is a thread I started at CNCZONE that follows my progress, there are also some pics in there. The machine is a lot more complete now but still needs a little tidying up. http://www.cnczone.com/forums/granit...f_granite.html
Here is a smiler machine that was up for sale in the USA on the 18th of FEB 2011. http://www.signweb.com/forum/for-sal...-8-x-12-router
14-05-2012 #5
Picture of machine taken today. Let me know what you would like to see and I will take some more.
GavLast edited by gavztheouch; 14-05-2012 at 01:25 PM. Reason: Add Text
07-06-2012 #6
07-06-2012 #7
Hi there, yes machine is still for sale. I will PM you my contact details.
Gav
07-06-2012 #8
07-06-2012 #9
Yes I have been using it to cut 18mm birch ply wood and I see no reason as to why it would not cut 25mm. The router is a 2hp hand held bosch type. So I would recommend upgrading to a much larger spindle and z-axis, this means you could cut through the 25mm a lot faster.
Do you have an example of the parts you would be cutting?
How you had any experience with CNC routing before?
Gav
07-06-2012 #10
thanks, never used a CNC before. it would be used to cut circular stage tops in sectors, ie a 4m diameter stage would be made up in 16 wedge shaped pieces, a bigger stage for example a 9m dia. would be made up of an inner circle 5m dia. from 16 sectors and an outer ring around them of 32 sectors to make the 9m. all in 25mm far eastern plywood. can any router head be fixed to this unit then. does it have the suction bed that hold the sheets down?
BUILD LOG: 3 Axis Router
By GTJim in forum DIY Router Build LogsReplies: 8Last Post: 22-06-2020, 08:49 AM -
BUILD LOG: 3 Axis CNC router
By JoeHarris in forum DIY Router Build LogsReplies: 658Last Post: 21-06-2020, 10:41 PM -
BUILD LOG: Wobbly: my first 3-axis router
By Sodster68 in forum DIY Router Build LogsReplies: 8Last Post: 20-01-2013, 10:28 AM -
3 axis cnc/router bed
By dudz in forum Marketplace DiscussionReplies: 23Last Post: 28-12-2012, 09:38 PM -
Need 6' x 4' bed, 4 axis router design.. Help..!
By fasteddy in forum Gantry/Router Machines & BuildingReplies: 29Last Post: 17-09-2010, 12:56 PM
