    An article on a new tool I found here
    Ralph Waldo Emerson
    My first thought after reading that article was why don't they just machine the bores with a standard boring tool with the block heated to operating temperature? It looks like they're discussing that in the comments section...
    Either way it's a fairly impressive tool.
    My initial thought was why go to the bother of building up then stripping down to measure high/low spots before machining again.
    However if you take a sample of blocks, build them up, run them, then strip down and measure, you'll find the common high/low points for a particular design. With that info, you can then machine the new blocks accordingly.
    But, given the extra costs involved, for what basically amounts to something that will only affect the run-in period, and maybe give a marginal increase in component life, I doubt many main stream manufacturers will use it. It's probably of more interest to high performance or truck manufacturers, where everything is about incremental gains for power or fuel economy.
  1. Any ideas or thoughts on making a edge finder come touch off tool
    By suesi34e in forum Electronic Project Building
    Last Post: 01-01-2020, 06:28 AM
  2. Steam Engine made of GLASS
    By WandrinAndy in forum General Discussion
    Last Post: 13-06-2013, 09:57 AM
  3. NEW MEMBER: model engine builder in somerset
    By Peter Griffin in forum New Member Introductions
    Last Post: 21-10-2012, 04:41 PM
  4. Making Aluminum offcuts - what tool?
    By lateAtNight in forum Tool & Tooling Technology
    Last Post: 28-07-2012, 02:44 PM
