12-12-2012 #6
Go down either the pillow block and double angular contact bearing route or get some shaft supports and 2 single AC bearings then, will be cheaper. Trouble is you'll get the ballscrews machined for this solution and unless you design it carefully you'll have to either get them re-machined or new ball screws as the machining won't be correct for your "propper" solution.
WANTED: FK12 fixed ballscrew support
By r0bsk1 in forum Items WantedReplies: 0Last Post: 29-10-2013, 10:21 PM -
FOR SALE: sbr12 supported rod
By johngoodrich in forum Items For SaleReplies: 4Last Post: 25-04-2013, 10:49 PM -
I need some help, Dukitec FK15 support unt - torque of the nut onto the ballscrew
By range3rrr in forum Lead Screws, Nuts & SupportsReplies: 0Last Post: 09-04-2012, 11:20 AM -
Ballscrew Support Bearings - Angular or Self Align or ??
By williamturner1 in forum Lead Screws, Nuts & SupportsReplies: 8Last Post: 02-10-2010, 02:38 PM -
Machining Ballscrews with a mini lathe (& ballscrew support questions)
By HankMcSpank in forum Lead Screws, Nuts & SupportsReplies: 15Last Post: 16-02-2010, 12:22 AM
