In Mach3 'Config' / 'Ports and Pins' / 'Input Signals', make sure you have the correct 'Port #' and 'Pin Number' for the 'Home' inputs, also make sure the 'Enabled' boxes are ticked. The port should be 1 but the pin number will depend how the inputs are wired into the breakout board.
You can go to the 'Diagnostics' page and watch the inputs change when you activate the switches with a metal object. If they work the wrong way round then check the boxes called 'Active Low' and this will reverse them.Last edited by EddyCurrent; 08-05-2014 at 04:15 PM.
The Following User Says Thank You to EddyCurrent For This Useful Post:
Huanyang VFD control plugin for Mach3, USB RS-485
By JayPunchbuggy in forum Spindles & Drive MotorsReplies: 19Last Post: 15-05-2013, 08:00 PM -
2 motors on X how do I setup Mach3
By phill05 in forum Artsoft Mach (3 & 4)Replies: 17Last Post: 04-02-2013, 09:33 PM -
Mach3 / Offsets / Tool setup etc
By dudz in forum Artsoft Mach (3 & 4)Replies: 0Last Post: 20-11-2012, 03:51 PM -
New CNC Router Setup Tool For Use With Mach3
By CambiumMachines in forum Manufacturer NewsReplies: 3Last Post: 08-06-2012, 04:14 AM -
HID interface for remote control of Mach3
By Smiler in forum Electronic Project BuildingReplies: 0Last Post: 10-05-2009, 12:59 PM
