    looking at converting the above but its the one with the larger table but less space underneath for screws. after getting some dimensions off the X and Y slide and the size of 16mm and 12mm ball nuts I think there is enough room, with a little machining for the 12mm nut, just. OR has anyone fitted screw to one and how did you go on??, plus is there any down side to using 12mm ball screws over 16mm.cheers
    Take that as no to dont know ,"Onwards and inwards"
    Looks like you will have to lead by example. For that size machine you would think 12mm screws might be sufficient, remember to provide access for greasing the ball nut.
    Quote Originally Posted by bmbaz View Post
    It might be worth contacting John S on this forum as I think he might have done these before. ..Clive
    Cheers all so far,just made up 2 dummy ball nuts to drawing spec and 2 shafts, 12&16 so I can physically size up,milling under the table and top slide on Friday, think I better start a build log
    Lee Roberts's Avatar
    Lives in Wigan, United Kingdom. Current Activity: Viewing Admin Control Panel Forum Superstar, has done so much to help others, they deserve a medal. Has been a member for 9-10 years. Has a total post count of 2,914. Received thanks 227 times, giving thanks to others 776 times. Made a monetary donation to the upkeep of the community. Referred 11 members to the community.
    That would be very helpful for others , looking forward to viewing.
    .Me
    .Me
  1. buying ball screws
    By bmbaz in forum Marketplace Discussion
    Last Post: 10-05-2014, 03:57 PM
  2. How to pre load screws
    By graham4877 in forum Lead Screws, Nuts & Supports
    Last Post: 14-08-2012, 11:07 AM
  3. Best way to machine ball screws?
    By Ross77 in forum Lead Screws, Nuts & Supports
    Last Post: 17-06-2012, 05:10 PM
  4. Two ball screws for my x axis and two motors, do i need two drivers?
    By luke11cnc in forum Gantry/Router Machines & Building
    Last Post: 12-08-2011, 12:55 AM
  5. Fitting new screws
    By Robin Hewitt in forum General Discussion
    Last Post: 15-02-2009, 09:34 PM
