Page 1 of 6 123 ... LastLast
    The Box
    The pallet it's on is 4' x 4'
    It was nailed and bolted together with speed bolts.
    The top off
    The exhaust pipe is squished ... the bag contains leads manuals software etc...
    A couple more sides off ...
    I opened it up to take out the extras.
    The air compressor
    The water pump
    The rotary table (4th axis)
    This reduced the weight a bit
    Once in the workshop, the tube compartment ... stuffed with air pocket packing
    And the tube ... still in one piece :)
    That all the photo's for now.
    I'll get it into a suitable position tomorrow and set about commissioning it
    More photos obviously.
    Over all I'm very impressed with the build quality , considering it's half priced and Chinese !
    The cabinet is well made, powder coated and fits well together.
    All the catches and hinges work as they should.
    It looks the job !
    Happy so far :D
    That looks very nice, great value too. Perhaps when you get it set up you can come up here and set mine up!!! Good luck. G.
    Thanks G
    I'll put on here how I get on.
    From what I've read, your corner problem is common for 'beginners'
    The laser power for cutting at full speed, is obviously more than is needed when it slows down for the corners ... I have no idea how to solve that ... A.T.M. I just know it needs solving :)
  4. The Following User Says Thank You to Want2build1 For This Useful Post:
  5. #4
    Looking good so far, thanks for sharing!
    .Me
    .Me
  6. #5
    hmmmm ... not there either, else I can't use any of my outfeed table !
    It really is bigger than I had imagined with a tape measure in my hand ! lol ... doh !!!
  7. #6
    Water pump in bucket and air pump (silent!)
    1st test cut ok :)
    Is just the test pattern in the controller rom..
    Cut 4mm MDF in default settings, 6mm in two passes.
    I've not calibrated. aligned or focused yet, but all is good so far :)
  8. #7
    nearly ready to move it to a temporary working place .. at the cost of not having space to work at the mo !
    This is it currently sat on my Wadkin table saw .. which isn't small !
  9. #8
    ok ... this will work for now ... I can use my cross cut sled again :)
  10. #9
  11. #10
    How's the laser going ? I would love to know how your getting on with it. When you get going fully test some acrylic 6mm and over and see if it does the edge cut at 90* I ask because a guy who spent £7.5k on a 1200x900 laser told me they cut at a slight angle and not 90* So keep the pics coming and the video please.
    Mike
  1. Laser Machine Grounding/Earthing
    By Want2build1 in forum Laser Machines & Building
    Last Post: 09-02-2015, 10:18 PM
  2. Laser Machine Eye protection
    Last Post: 19-05-2014, 01:46 PM
  3. How to save laser machine cost
    By Zoe Zhang in forum Manufacturer News
    Last Post: 06-09-2012, 03:41 AM
  4. Chinese CNC machine modifications - Discussion
    By craigrobbo in forum Milling Machines, Builds & Conversions
    Last Post: 14-05-2012, 06:51 PM
  5. WANTED: GCc Laser Pro or Epilog Laser Cutter Machine
    By Brownhills school in forum Items Wanted
    Last Post: 10-05-2012, 04:30 PM
