    I have a very nice ISEL GFM 4433 to sell. Isel is German built and their machines span top end routing to low end metal machining.
    The machine has a 440 x 330 cutting size and about 150 Z travel. Its a stepper motor machine built around aluminium frame by ISEL and its remarkablv versatile.
    Great for fast movements over 3d surfaces. Yet I have just CNC machined aluminium wheel spacers out of 2" plate with a 10mm cutter!
    Previous owner has done one naughty on the bed but its small and insignificant.
    Has the Axemotion upgrade making smooth 3d travel in all axes at over 25mm per second.
    Kress router, plus 5:1 head that does about 5000rpm max and is ideal for metal.
    Has full enclosure and vacuum pipe installed. Keeps the mess and noise in so good for jobs that run overnight.
    Also z height touch swith.
    Sets of collects and nuts for both machining heads, ER 11 and ER16.
    Has a working but PC and screen that is alittle slow but adequate.
    Comes with a licenced copy of KAY, an easy USB based communication and job run software designed around these machines.
    Also working copy of Deskproto, easy to learn but very powerful CAM software. Its the expert edition with 5 axis capability. See their website. I have been trained on Powermill but this does the job adequately without having to be trained and a full time user.
    Also basic 4th axis fixture intended to allow automaitc z flips when machining double sided objets and you need perfect alignment. It needs finishing setting up etc etc.but it simply plugs into the machine with a 9 way connector.
    I will give a buyer a bit of training if you want.
    Mike
    07713327210
    Still have...? and what price please, with thanks
    Chaz's Avatar
    Lives in Ickenham, West London, United Kingdom. Last Activity: 3 Days Ago Has been a member for 9-10 years. Has a total post count of 1,605. Received thanks 110 times, giving thanks to others 69 times.
    Quote Originally Posted by finka View Post
    You do realise this was a 2015 thread?
    That said, I believe mitip still has the machine.
    I know this isn't related to the sale of the machine, but I am about to purchase one of these and was told that it didn't take g-code. Is this true? If so, how can I use g-code and not use galaad? I want to use something like mach4 - seems much more standard.
    Cheers,
    L
  1. SOLD: Indexer, ISEL CSD 405-IMC and GFM 4433 controllers
    By badgerman in forum Items For Sale
    Last Post: 27-06-2014, 10:46 AM
  2. ISEL GFM 4433/ educam 44
    By macomk in forum Machine Discussion
    Last Post: 18-06-2013, 10:01 PM
  3. FOR SALE: isel gfm 4433
    By plotter in forum Items For Sale
    Last Post: 09-10-2012, 06:00 PM
  4. FOR SALE: ISEL Automation router GFM 4433
    By Nic in forum Items For Sale
    Last Post: 19-12-2011, 06:07 PM
  5. ISEL Ball nut
    By cncezee in forum Lead Screws, Nuts & Supports
    Last Post: 02-10-2010, 12:11 PM
