21-06-2016 #1
Hi everyone, another day, another set of issues lol.
due to lack of foresight when I started designing my build, I didn't account for requirement of large Z clearance and movement due to fear of deflection and what not. I could have definitely used an extra 100-200mm but can't go back now.
I purchased this vise when I was in UK last year http://www.rdgtools.co.uk/acatalog/L...ine_Vices.html
its around 3 inches high if I'm not mistaken, that's way too much for the space I have (150mm Z travel assuming no tool in spindle), its okay for small parts and small tools but otherwise cant do much.
Is there a solution that allows me flexibility of vise directly on the T-Slot table with enough clamping force?
I have the M8 version of these mitee bite fixture clamps http://www.miteebite.com/products/fixture-clamps/ that are helpful for fixtures but wondering if I can use them for a vise like setup?
any thoughts or advice?
21-06-2016 #2
You could have a look at 56mm Vertex Free Vices and a search for Limitless Milling Vice may give some interesting results.
If you need a very low profile vice for a T slot table making your own in 3 parts isn't terribly complex, Google low profile milling vice and click images for lots of good shop-made options,
Regards,
NickYou think that's too expensive? You're not a Model Engineer are you? :D
21-06-2016 #3
I could, but don't they have tight tolerances and specifications? I wouldn't be able to achieve that for sure. thanks for the suggestions!
21-06-2016 #4
Nothing that is impossible with good old manual bench-work, a sadly overlooked skill set in the "off the shelf" Maker Generation!
If you use lengths of 01 Tool Steel ground stock for the fixed jaw, moving jaw and the female threaded section for the screw you can make one with a bench, vice, hacksaw, scriber, centre punch, drills & a tap, some large threaded rod and some nuts.
Probably with the emphasis on the latter ;-)
25-06-2016 #5
How about this ? http://www.arceurotrade.co.uk/Catalo...Milling-Vice-6
You may be able to find a smaller version.
25-06-2016 #7
Googling "Low profile milling vice" and selecting images shows half-a-dozen good home made options in the first couple of pages that would class as both "Functional" and what was in my day "O Level Metalwork"
NEE AMC-E schematic or suggested alternative control boards
By DaveBee in forum General ElectronicsReplies: 2Last Post: 05-03-2019, 04:31 PM -
CW8060 or alternative?
By Tenson in forum Motor Drivers & ControllersReplies: 4Last Post: 03-02-2014, 07:56 PM -
Alternative slides and guides
By Swarfing in forum Rails, Guideways & BearingsReplies: 14Last Post: 23-04-2012, 07:14 PM -
AutoEditNC alternative?
By DanielF in forum Programmers CornerReplies: 12Last Post: 22-02-2012, 12:46 PM -
Cheap Sign Foam Alternative
By action-kat in forum Machine DiscussionReplies: 5Last Post: 20-09-2011, 12:35 PM
