Thread: larger stepper motor needed
hi chaps. I purchased a router off ebay and the stepper motor I have will not move the x axis. the motor is a 2.4nm 4 wire job at 3 amps. the router is using normal lead screws not ball screws. the axis can be moved by hand, but I think its just too heavy for the motor for the motor to deal with.
so my question is what can I do to improve this.
the motor is a 23HS2430B 1.8 3amp and I am using a HG08 breakout board from cnc4u,
what would be the largest motor I can het away with on 4 wire, and would I need to give it its own power supply.
thanks michael
29-05-2017 #3
hi, its a 400 watt 36v 11 amp job.
29-05-2017 #5
hi, the motor runs ok off the machine. the motor can move the gantry if I help it a bit, but is not able to move it unaided. I have tried retuning it in mach3 but I think that there is just too much weight for the motor to deal with. the drivers are just 4.3 amp units from ebay
29-05-2017 #8
the drivers are *CW-5045 from cnc4u
RFQ: 3 motor mounts needed,
By nobby in forum Projects, Jobs & RequestsReplies: 1Last Post: 28-05-2017, 04:23 PM -
Fusion 360 part is 4 x larger, what am I doing wrong?
By terry1956 in forum Fusion 360Replies: 3Last Post: 10-03-2016, 09:25 AM -
How do I wire a stepper driver to a stepper motor?
By swood1 in forum Stepper & Servo MotorsReplies: 7Last Post: 21-09-2014, 05:40 PM -
Stepper Motor Driver - cheap similar to ArcEuro 4.2A Bi-Polar Stepper Motor Driver
By craynerd in forum Motor Drivers & ControllersReplies: 1Last Post: 16-03-2014, 07:29 PM -
Truss Structures - in larger gantry router design
By CharlesJenkinson in forum Gantry/Router Machines & BuildingReplies: 5Last Post: 10-02-2014, 09:56 PM
