Page 2 of 2 FirstFirst 12
    Essentially, I think you have a geometry issue here. On the gantry, the arm is positioned and pivoted so that the pinion moves roughly at 90deg to the rack. However, the X pinion arm is pivoted so that the pinion moves almost parallel to the rack. I know that it's not quite parallel, but it's close enough that even with a very strong spring, there is relatively little force acting to keep the pinion engaged. Would it be possible to use a fixed vertical plate going down from the gantry with a pivoted horizontal arm carrying the pinion? I can see that that might give belt tension issues, but that might be an easier problem to fix!
    The solution for belt tensioning would be to have two belts, one on the vertical arm and one on the horizontal, with two pulleys on a shaft at the pivot point.
    Thanks guys, am going to fix the shoulder drops, then pivot the plate on the same axis as the rack. this will require more belts. Matt
    Lee Roberts's Avatar
    Lives in Wigan, United Kingdom. Current Activity: Viewing Moderator Control Panel Forum Superstar, has done so much to help others, they deserve a medal. Has been a member for 9-10 years. Has a total post count of 2,914. Received thanks 227 times, giving thanks to others 776 times. Made a monetary donation to the upkeep of the community. Referred 11 members to the community.
    I was thinking split the plate, fix the top, pivot the bottom, use a bigger belt (probably) and design in a spring loaded cam follower feature that would auto adjust the timing belt tension as the pinion mechanism/plate adjusts in real time.
    .Me
    Whats the software of choice for plasma? and can anybody steer me in the right direction ? :D
  5. #15
    king did you ever get the plasma side of things up n running?i think your fairly local to me,im after some skate bearing type carriages to be plasma cut for a 4x4 soon if you can oblige ps you sound as nervous as i do
  1. FOR SALE: CNC Plasma Cutter For Sale
    By billm in forum Items For Sale
    Last Post: 17-07-2012, 07:50 AM
  2. Which Plasma Cutter to buy?
    By AndyG in forum General Discussion
    Last Post: 02-12-2011, 09:34 AM
  3. cnc plasma cutter problems
    By oadamo in forum General Discussion
    Last Post: 21-06-2011, 09:28 PM
  4. First Plasma Cutter
    By antsals in forum Plasma Table Machines
    Last Post: 16-05-2011, 07:58 AM
  5. Plasma Cutter Drive
    Last Post: 23-08-2010, 05:28 PM
