Thread: High Precision Homing Switch
15-04-2018 #1
Looking for a high quality homing switch so that I can get my Lathe's X Axis set correctly and allow my tool changer to be consistent.
When looking at proximity switches, how do you know if its high quality? I did see a test a while ago where a guy on youtube tested a number of them and found a mechanical switch with no arm seemed to be the most reliable.
As I dont have index homing (stepper), what are my options?
15-04-2018 #2Looking for a high quality homing switch so that I can get my Lathe's X Axis set correctly and allow my tool changer to be consistent.
The standard proxy switched I find OK..Clive
15-04-2018 #3
15-04-2018 #4
15-04-2018 #5
15-04-2018 #6
I used an opto slot sensor on my old lathe, and there was never any measurable variation. I used RS part number 480-5231 however I see that part has now been discontinued. The only problem was I had to make sure a bit swarf hadn't landed in the slot prior to homing, as I never bothered enclosing it.
The new lathe uses proximity combined with servo index homing.
You could combine a proximity or microswitch with a slot sensor on the stepper, provided you can add a suitable slot to the stepper/ballscrew, to essentially give you a poor mans index homing.Avoiding the rubbish customer service from AluminiumWarehouse since July '13.
The Following User Says Thank You to m_c For This Useful Post:
15-04-2018 #7
Chaz
I have a Balluff mechanical switch which are very good, I don't mind sending it over for you to try.
Just pm me your address if you want to try it. I will post a link to the switch if I can find it on the RS site.
Regards
Andy
15-04-2018 #8
Thanks, something like this - https://uk.rs-online.com/web/p/photo...nsors/1254515/ ?
15-04-2018 #9
15-04-2018 #10
Homing with proximity sensors
By routerdriver in forum General ElectronicsReplies: 4Last Post: 19-12-2017, 06:32 PM -
Problem with homing
By Andyman in forum Gantry/Router Machines & BuildingReplies: 4Last Post: 22-03-2016, 07:56 PM -
homing problems in mach3
By johngoodrich in forum Artsoft Mach (3 & 4)Replies: 2Last Post: 17-09-2011, 08:28 PM -
Homing Switches
By m_c in forum General ElectronicsReplies: 3Last Post: 04-11-2010, 11:21 PM -
Limits or homing switchs???
By Ross77 in forum Computer SoftwareReplies: 11Last Post: 28-03-2010, 03:17 AM
