    Hello friends, I bought Chinese CNC mini machine that came with fake Planet CNC card installed and software does not work, This machine accepts both kind of inputs, Parallel Cable and USB. I decided to buy Planet CNC MK3 Controller and software License.
    But before taking further step i just want to get some feedback/opinion from you guys if you think Planet CNC MK3 is a good controller and easy to install/configure etc. being a hobbyist i do not have enough time to setup complicated things, it looks me like installation is very state forward as i have to connect parallel ports. I'm also posting picture of my CNC mini and its Parallel Port based stepper motor driver.
    My major objective is PCB milling and some time cutting, I'm also concerned about how good it can engrave.
    (i found this section as best match to my question, please push me to right one if you think)
ID:	24154   Click image for larger version.
    Sairfan 1 - I have converted an Isel router to Planet CNC and found the process quite easy. I am no machine builder and if I can do it, must be easy. I moved from Mach 3 and find Planet CNC far better. The new TNG software still has a few minor peripheral bits to resolve. But which controller system on the market does not? I particularly like the Warp feature and use it frequently to engrave on irregular or 3D surfaces. I believe it was originally developed for PCB work.
  3. I can't help you with Planet CNC, I am using UCCNC and I am happy with that. Moved from Mach3 and I find it much better for my needs. Also milling a lot of PCB and on your machine I'd worry about that spindle. I had a similar before, but it was not performing very well.
    BTW, I am also a hobbyist and I see the opposite, because it is a hobby, I have all the time in the world to spend time with setup or whatever. It is not my daily bread, so time is not an issue.
    Quote Originally Posted by Leadhead View Post
    Thanks for help, i bought new module and software license, I'm new to CNC machines, I found that controller card supports limit switches but my machine does not have, I believe it can work without limit switches but i want to know how important it is to install limit switches, are they really helpful or something we can avoid.
    thanks.
    Limit switches are a personal thing. I have them on one machine but never use them as I do not trust their accuracy and thus the repeatability. So on my main machine I just use the "soft limits" as an idiot border, so to speak. I zero XY&Z independently each time. Or put a hard stop(s) on the bed if making multiples. If I need to home all, or home XY, or just Z the TNG buttons on the l/h side bar are efficient and effective.
    So for my part, limit switches are not needed. I work perfectly well without them.
  6. Quote Originally Posted by sairfan1 View Post
    thanks.
    There are different schools... some prefer limit switches, some don't. Personally I would not run a CNC without limit switches to prevent unintentional runaway. On my 3D printer I only have home switches, and those work as limit switches for one end of the axis, but have no limit switches at the other. Now and then I make a mistake resulting in hitting the wrong end, and even with the weak NEMA17 motors it sounds pretty violent. I want my CNC to stop in a more controlled and less violent way so I have limit switches at both ends to prevent that. On the other hand, I don't use home switch on my CNC at all, since I always start from zero on the material I work with and I set the zero each time I need to.
    To stop confusion. Limit switches and home switches are different things, homing switches need to be accurate and reliable. Limit switches do not need to be accurate.
    But it is possible to use a home switch as a limit switch combined. In this case you can make the machine set the SOFT limits so when homed the machine knows where it is and thus should not crash at the other end.
  8. Quote Originally Posted by Clive S View Post
    Yes. And to make things even clearer, the difference between hitting the home switch and hitting the limit switch is that when the machine hits the home switch (soft or hard, makes no difference here), it decelerates in a controlled manner and not losing position. Limit switches are for safety reason, so when the limit switch is hit you want the machine to stop as fast as possible and don't care about losing position. After hitting the limit switch the machine must be homed again, or zeroed at the right position, whichever you prefer, otherwise you will not be able to continue the job.
    Yes, soft limits CAN prevent you hitting the wrong end, but that assumes that the machine was homed initially when the machine is powered on and that the positions are still safe to use. This is not always the case, for example after stalling or some other error which can cause offset or lost or extra steps. Especially with my 3D printer, when I power it on all axis values are zero, regardless of where the extruder head is positioned, so hitting the wrong end is easy. Of course, this can be prevented through prohibiting any move except homing after power on, but since it is just a 3D printer, I don't care about that.
  1. Planet CNC initial setup and limits?
    By ravihotwok in forum General Discussion
    Last Post: 22-06-2017, 08:09 AM
  2. Replies: 0
    Last Post: 13-12-2015, 08:22 PM
  3. Replies: 7
    Last Post: 18-01-2014, 07:04 AM
  4. Reversed axis on a AXYZ 6010 after installing DNC controller software...
    By RickyThunders in forum Machine Control Software
    Last Post: 12-02-2013, 03:56 AM
  5. HME Technology router NEE AMC-E controller WinAMC software
    By artmin in forum Motor Drivers & Controllers
    Last Post: 24-01-2012, 11:29 PM
