Thread: DIP switch setting
21-09-2022 #1
I'm rebuilding a 60/40 CNC.
I'm using DM542T drivers and Nema 23HS45-4204S stepper motors
The amps/phase rating for the motors is 4.2 amps
The dip switches can be set at either 3.76 or 4.5 amps
Which should I use ?
Thanks Evans
Though steppers can be run pretty hot I don't think you should exceed the phase current rating, so 3.76 max. If they give enough torque you could reduce the current so they run cooler, but steppers commonly run pretty hot.
21-09-2022 #3
The 4.5A is the peak value, so you can safely set it to the maximum. Also, the motor is rated at 4.2A, but that is not and absolute maximum +/- 10% is normal margin, so you can safely use it with the driver set to 4.5A. On the other hand, why set it to maximum unless you need the extra power? So set it to 3.8A full current, and if it is good and not losing steps then keep that setting.
Note that steppers operate at very high temperature, so don't panic if you burn your hand when touching it. 60°C -- 80°C is OK, and that's far more than what your hands tolerate. It can feel hot already around 40°C, which is pretty cool for a stepper.
Limit switch problem
By Mikes Planes in forum General DiscussionReplies: 8Last Post: 02-09-2021, 10:34 AM -
Switch identification
By mekanik in forum General DiscussionReplies: 5Last Post: 06-03-2017, 09:47 AM -
How to mount the switch?
By routercnc in forum General ElectronicsReplies: 2Last Post: 10-03-2015, 01:37 PM -
Proximity switch NPN or PNP
By Matt81 in forum General ElectronicsReplies: 9Last Post: 19-04-2014, 11:38 AM -
Switch for motor?
By newtoid1986 in forum Electronic Project BuildingReplies: 4Last Post: 27-06-2012, 03:37 PM
