Thread: Aluminium sculpture to be CNC'ed
Hi There
I am a sculptor looking to get this piece CNC'ed:
The piece is currently approx 1 meter tall but I reckon I could get away with scaling it down to 65 cm in height. It may also be CNC'ed in sections and I can tig weld it together afterwards.
The budget is £800.
Is this possible?
Many Thanks
DaveLast edited by dav; 08-01-2012 at 09:32 PM. Reason: change of dimensions on image
07-01-2012 #2
deleted post
07-01-2012 #3
07-01-2012 #4
Hi Jonathan
Yes I work in a sculpture fabrication workshop and have some access to a small foundry and resin bonded sand facilities, if the piece was able to be milled in wood ...and cast in sections say the cloud ,the body and the helmit I could cast these in aluminium and tig weld them together after. although the resin bonded sand, aluminium and gas would eat in to my £800 budget a bit. What would it cost to have the former's milled for a 65cm tall version in wood ?
David
07-01-2012 #5
Hi Jonathan
Yes a former made of would could do the trick, I work in a sculpture fabrication facility and have access to a small foundry. If 3 former's for the piece could be made (the cloud, the body and the helmet) I could make 2 piece resin bonded sand moulds for each of the former's and cast them, the 3 cast aluminium pieces could then be tig welded back together. I would not be able to offer the full £800 though as I would need to take resin bonded sand, gas, aluminium and finishing etc out of the budget for it. What price do you reckon I could get the formers milled in wood for?
Many Thanks
David
07-01-2012 #6
You can use either, but here wax is going to be easier as there's no obvious place to split the mould to get a former out.
Nice link from 'How it's made'- didn't know there were rapid prototypers that use metal, not plastic. How it's made is such a good program, even better if you mute it.
07-01-2012 #7
custom 3d models for CNC, sculpture, portraits, reliefs
By veres in forum Opportunities Available & SoughtReplies: 80Last Post: 3 Weeks Ago, 03:23 PM -
RFQ: 3d sculpture, portraits, reliefs
By veres in forum Projects, Jobs & RequestsReplies: 15Last Post: 01-10-2012, 03:15 PM -
3d sculpture of Marilyn Monroe
By Kevin1970 in forum Computer SoftwareReplies: 4Last Post: 16-06-2012, 07:11 PM -
Aluminium passivation - for aluminium to be used outside
By CHudson in forum Metal Finishing TechniquesReplies: 4Last Post: 06-04-2011, 09:18 PM -
MDF or Aluminium
By rob_colby in forum Gantry/Router Machines & BuildingReplies: 3Last Post: 24-10-2010, 09:36 PM
