Thread: Best Place To Buy Couplings?
16-04-2013 #1
Hey All,
I was in the process of making a Cardiff City plaque to hang up and it started to double line cut again. Scrap that piece of timber and grab the allen key to make sure that everything was tight and because the opening they give you to get to the coupling was facing away from me I decided to undo the motor and turn it - ehh convenience. The following two fotos shows what I found - methinks it's not supposed to look like this, no wonder it skipped a line.
Is there a recommended place to get replacements of the decent variety? Something that will preferably last longer than three engraving pine jobs!!
Carl
Cardiff City Supporter ~ Real Sporting de Gijon Supporter ~ Vintage Synthesizer Collector
La gente dice que tu vida esta planeado, me gustarķa encontrarse con el jefe de planificacion para que yo pudiera darle un punetazo en la cara!
16-04-2013 #2
Carl,
Bad forum to ask questions in as you can't make replies in this forum, hence the new thread.
This coupling question often gets asked.
There is only one design of coupling that can handle mis-alignment in two axis and still work. That is an Oldham coupling.
Oldham Coupling Flash Animation
If you were in the UK I'd say Farnell, CPC, RS or Arc
The 2, 3, 4, jaw lovejoy type couplings whilst being cheapare not zero backlash or able to handle misalignment in both axis.
The type you have I hate with a vengance and is about as much use as a stick of celery and two hose clips.John S -
The Following User Says Thank You to John S For This Useful Post:
Thread moved and merged.
.Me.Me
16-04-2013 #4
Hi Carl,
If couplings are breaking that easily then I would check the alignment of screw and motor and look to see (with a dial gauge if poss.) whether the motor or leadscrew shafts are bent. if not then try to get the shafts as co-axial as possible.
It may be that your machine suffered as mine did at the hands of a careless (I'm being generous to the moronic oaf) delivery driver.
Cheers,
RobLast edited by cropwell; 16-04-2013 at 02:54 PM.
Best place to buy parts for a cheap first CNC.
By Boscoe in forum Marketplace DiscussionReplies: 9Last Post: 17-07-2013, 06:19 AM -
Best place to get ballscrews?
By Ross77 in forum Lead Screws, Nuts & SupportsReplies: 6Last Post: 15-04-2013, 10:09 PM -
Stepper shaft couplings - can you ID these?
By HankMcSpank in forum Stepper & Servo MotorsReplies: 17Last Post: 15-04-2012, 03:46 PM -
I'm in the right place
By luke11cnc in forum General DiscussionReplies: 8Last Post: 04-12-2011, 01:37 AM -
Pick and place log
By Robin Hewitt in forum Pick & Place MachinesReplies: 4Last Post: 22-10-2010, 03:00 PM
