    I have pneumatic cylinder on on milling machine tool changer that has a leaking internal seal. It works on the outward stroke but air exhausts out of the back valve on the return stroke.
    Does anyone know if I could replace the internal seal on this cylinder?
    If not does anyone have a spare lying around?
    The cylinder is a Joucomatic Isoclair 435 50 438 c 25 A 150 (P max 140psi)
    Chaz's Avatar
    Lives in Ickenham, West London, United Kingdom. Last Activity: 3 Days Ago Has been a member for 9-10 years. Has a total post count of 1,605. Received thanks 110 times, giving thanks to others 69 times.
    Quote Originally Posted by jamesgates1000 View Post
    If you dont come right, I can point you to someone that can help. I bought a missing actuator for my Denford from these guys, were helpful and very good.
    Hi Chaz, thanks I have been quoted £70 delivered, was yours source any cheaper? Thanks
    Chaz's Avatar
    This is what I paid. My actuator is not 'soft stopping', so doesnt have the adjustment at the end of the travel but still works none the less.
    1off - 25mm Bore x 160mm Stroke D/Acting Pneumatic Cylinder @ £40.39
    1off - 3 Station Solenoid Valve Manifold @ £24.71
    3off - 1/4"bsp 5/2 Solenoid/Spring Valve 110v c/w Led DinPlug @ £27.00 each
    (*The easiset option for the 3 way valve is to use a 5 way and blank one of the outlets)
    4off - 1/4"bsp x 6mm Straight Adaptor @ £0.65 each (Manifold Inlet & Vent / Outlet for 3 way Valve)
    4off - 1/4"bsp x 4mm Straight Adaptor @ £0.65 each (Outlets for 5 way Valves)
    4off - 1/4"bsp Blanking Plug @ £0.60 each (1off for 3 way valve / 3off for blanking one side of valve manifold)
    1off - Carriage @ £10.00
    Total @ £163.70 + Vat
    The supplier details are:-
    Shelley Automation Ltd
    Block One
    Nortonthorpe Mills
    Scissett
    Huddersfield
    HD8 9LA
    Tel: 01484 860920
    Fax: 01484 860672
    Email: [email protected]
    VAT: 694 8526 78
    Thanks for the replies.
    Went to my local pneumatic supplier in Bristol(Harrier Pneumatics) and got a Parker PIA-5025MS-0150 as a direct replacement for £64.
    ATC is working fine now.
  1. FOR SALE: Denford Triac
    By asto in forum Items For Sale
    Last Post: 07-02-2016, 08:28 PM
  2. Help Denford triac p.c.
    By mikeulike in forum Denford Mills
    Last Post: 02-06-2015, 03:59 PM
  3. RFQ: Triac / Mach 3 help
    By suesi34e in forum Projects, Jobs & Requests
    Last Post: 10-08-2013, 01:59 PM
  4. WANTED: Wanted Denford Triac CNC Mill
    By angusnoble in forum Items Wanted
    Last Post: 15-07-2012, 06:45 PM
  5. FOR SALE: Univer pneumatic cylinder
    By m_c in forum Items For Sale
    Last Post: 18-12-2008, 09:27 PM
