Page 1 of 4 123 ... LastLast
    dudz's Avatar
    Lives in Dunedin, New Zealand. Current Activity: Viewing Has been a member for 9-10 years. Has a total post count of 281. Received thanks 2 times, giving thanks to others 69 times.
    I have a Chinese motion controller for my cnc, which has been Ok, but does have issues (but rarely).
    So I want a better quality motion controller but not top of the range expensive kit.
    I came across these which seem to be reasonably priced. (more exp from CNC4you)
    Anyone have any exp with these ?
    http://www.cs-lab.eu/en/produkt-18,2...onnectors.html
    Yes I've fitted loads of them and they are top notch piece of kit.
    Only down side to the IP-M is if you need slaved axis then it doesn't home to independant Home switches for each motor but other than that they are excellent with industrial quality and bullet proof 24v I/O and built in speed controller. Best of all they remove the need for a BOB which can't be under estimated what an advantage that is.
    Software and support is top notch has well.
    I only try to use Cslabs controllers these days when building machines if the budget can run to it and even then I'll sometimes Trim else where to make it so can use if doesn't.!. . . . Recommended it in a heart beat.
  3. The Following 2 Users Say Thank You to JAZZCNC For This Useful Post:
    Having just converted my Chinese 1325 from DSP to MACH3 and the CSLABS IP-S (with much help and advice from JAZZCNC) I would heartily recommend the CS-labs kit. Like having a new machine
  5. #4
    dudz's Avatar
    Good to hear.
    My PC sometimes freezes in the middle of a job and the motion controller rarely but however does loose communication with the PC, causing unexpected stops. So I need to replace both the motion controller and the PC.
  6. #5
    I bought a gigabyte brix compact PC that I have mounted inside the control cabinet, very compact and does the job very well, very low power usage as well.
  7. #6
    dudz's Avatar
    Just had a look at them. Good idea, but more exp than normal used towers eh ?
  8. #7
    Mine cost me 180 Euro with 500gb HD and 4GB ram. didn't think it was too bad, only uses 11watt of power in standby as well. Doesn't come with OS though. (nice avatar by the way, is that your bike?)
  9. #8
    dudz's Avatar
    Quote Originally Posted by alboy View Post
    Nope, thats a good deal IMO, what speed Processor ?. I will keep my eyes open for such a deal
    Avatar is a Ducati 996 (same as I used to have).
  10. #9
    Here's the spec of the PC
    Brand Gigabyte
    Item Weight 1 Kg
    Product Dimensions 19 x 16.6 x 8 cm
    Item model number GB-BXBT-2807-500/4
    Series GB-BXBT-2807
    Processor Brand Intel
    Processor Type Celeron D
    Processor Speed 2807 GHz
    RAM Size 4 GB
    Computer Memory Type SODIMM
    Graphics Card Description Intel HD Graphics
    Operating System None
    More than enough for running MACH3.
  11. #10
    dudz's Avatar
    Ok. Just ordered an IP-M
  1. USB/Ethernet controller for Mach3/4 advice
    By paulus.v in forum Control Hardware & Systems
    Last Post: 17-02-2015, 09:37 PM
  2. FOR SALE: Galil 1880 8 axis PCI motion controller
    By Boyan Silyavski in forum Items For Sale
    Last Post: 03-06-2014, 07:39 PM
  3. eBay: Galil DMC-1580 Motion Controller 8-Axis
    By Boyan Silyavski in forum Items On eBay UK
    Last Post: 25-12-2013, 10:30 AM
  4. CSMIO/IP-M vs Ethernet SmoothStepper (Begone foul parallel port!)
    By Greeny in forum Control Hardware & Systems
    Last Post: 14-11-2013, 11:59 PM
  5. USB and Ethernet Mach3 motion controller PLCM-E3
    By Purelogic R&D in forum Manufacturer News
    Last Post: 29-12-2012, 09:38 AM
