Hi All,
Just signed up this forum, i am currently designing a small (Large Desktop?) sized CNC Router for our business, it will primarily be used to machine 1mm Intumescent Fire Sheet, but also for producing one off parts for some of our older machines (Aluminium, Steel etc?). We have two much larger CMS Routers already that we use for production of which i create C Based programs for. I have a pretty sophisticated knowledge of building 3D Printers but this will be my first router, i had found this design online and really like how robust it looked:
https://jeremyyoungdesign.com/2016/0...inal-assembly/
So the design is heavily based on that machine.
So far it is looking to be built from the following:
Frame - Genuine Rexroth Extrusions & Connectors.
Gantry - 18mm Aluminium - Bespoke Plates, Would need to have these made (Pricey?!).
Low Profile L1016 Linear Rails & Carriages from Automotion Components - On all Axis
4NM Nema 23's on All Axis ( This Kit: https://www.cnc4you.co.uk/CNC-Kits/S...-4-Axis-Nema23 )
Dual RM2010 Ballscrews on X Axis
Single RM2010 Ballscrew on Y Axis
Single RM1605 Ballscrew on Z Axis
Appropriate Fixed & Floating Blocks on each Axis.
Ebay / Chinese 2.2kw Water Cooled Spindle
So that is the rough spec of the machine currently, the main things i am concerned about so far are:
- Controllers - The motor & driver kit comes with a parralell breakout board, however i want the machine to be compatible with newer Laptops (Windows 10 x64), when building 3D Printers i tend to use Clone Smoothieboards, would these also be suitable for this CNC Build? They perform well and are cost effective, also have stepper signal breakouts.
- Endstops - Mechanical endstops are common practise on 3D printers, i see many Router builds done using proximity sensors or hall effect sensors, are any recommended for maximum repeat-ability?
- Resolution - Will the 10mm pitch and 5mm pitch provide me with a balanced resolution / speed combination, i was advised previously that 2005 screws on the X & Y might hold back achievable speeds - or that i might be disappointed with the feed rates they would achieve.
- The build this is based on uses Aluminium for the majority of the Gantry and Z Axis plates, would steel also be acceptable? I was worried about making he gantry too heavy.
- I was considering buying the ballscrews from china, if they arrived with runout evident, could they be straightened, or might they straighten out once fixed in position?
- Might anyone recommend a company / individual who cold produce the bespoke plates.
Any help / criticism / heads up on missed items would be greatly appreciated.
Alex
