Thread: 1200mmX900mmX170mm 4axis cnc
28-07-2021 #331
03-08-2021 #332
Congrats Nick! Isn't it fantastic when things start moving?! Getting very close now!
I think the drivers being enabled when disconnected is the default behavior. I changed mine in the protuner configuration software to need the enable signal in the opposite direction. My thoughts being that an active signal of "yes motor you can move" is better than "no signal means everything is okay" because if a wire got disconnected it fails into a safe state.
03-08-2021 #333
03-08-2021 #334-use common sense, if you lack it, there is no software to help that.
Email: [email protected]
Web site: www.jazzcnc.co.uk
04-08-2021 #335
30-12-2021 #336
The ungliest cnc ever!
https://www.youtube.com/watch?v=IIqcCCCgPMY
30-12-2021 #337
30-12-2021 #338
31-12-2021 #339
The Following User Says Thank You to Kitwn For This Useful Post:
31-12-2021 #340
cnc 4axis hot wire mach3;
By maikonesk in forum Hotwire Cutting MachinesReplies: 3Last Post: 07-08-2015, 02:15 PM
