    Hi I was looking for Epoxy to level my linear rails. I came across Reckli Epoxy pb. It has a viscosity of 230 mPa/s. It's cheap 13€/11GBP per kg.
    Do you think it's worth a try?
    Thanks a lot
    Felixhttps://cloud.tapatalk.com/s/5cb75154...poxy_PB_en.pdf
    Sent from my MI 6X using Tapatalk
  2. The Following 2 Users Say Thank You to feldah For This Useful Post:
  3. #2
    AndyUK's Avatar
    Lives in Southampton, United Kingdom. Last Activity: 3 Weeks Ago Has been a member for 6-7 years. Has a total post count of 469. Received thanks 100 times, giving thanks to others 43 times. Referred 1 members to the community.
    Most of us use the West Epoxy system, which is quite common. The 105 resin with the 209 extra slow hardener is the way I'm going with mine - but it costs about 5-6x times the version you've posted.
    Theres a rather good discussion of the topic here:
    http://www.mycncuk.com/threads/8197-...-for-levelling
  4. The Following 3 Users Say Thank You to AndyUK For This Useful Post:
  5. #3
    Hey yes I know the thread. But the 105/209 has a way higher viscosity with 600.
    It just has a bit longer cure time which may give it a bit more time to settle
  6. The Following 2 Users Say Thank You to feldah For This Useful Post:
  7. #4
    On my routercnc YouTube channel I had a few goes at mixing and laying the West epoxy. You can see what is involved and how it turned out. Here is Episode 15
    https://youtu.be/Ax5Ib7GcTqE
    Also in Ep 17 and a few episodes later for the Y rails. This may help decide whether to go with the West system or not.
  8. The Following 3 Users Say Thank You to routercnc For This Useful Post:
  9. #5
    Yes I followed your episodes interested. But I wouldn't have heated the epoxy beforehand. West system recommends heating the surface rather then the epoxy. But I wouldn't do it at all as heating and cooling brings shrinking I would say.
    I was thinking to test my built channel with ethanol for leaks.
    I think I will give it a try with the epoxy I found it's nearly a third of viscosity. And price seems to be fair too
  10. The Following 2 Users Say Thank You to feldah For This Useful Post:
  11. #6
    Mud's Avatar
    Lives in Bristol, United Kingdom. Last Activity: 11-12-2020 Has been a member for 3-4 years. Has a total post count of 23. Received thanks 3 times, giving thanks to others 0 times.
    Easy Composites IN2 is also very thin and very slow. The quoted demould time of 24hrs is more like 36+ in my experience. Disclaimer: I have no experience using it for levelling things.
  12. The Following 2 Users Say Thank You to Mud For This Useful Post:
  13. #7
    Yes but still 600 compared to mine having 230
  14. #8
    Mud's Avatar
  15. #9
    Lives in Marple Stockport, United Kingdom. Last Activity: 11 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has been a member for 9-10 years. Has a total post count of 3,333. Received thanks 618 times, giving thanks to others 78 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    Quote Originally Posted by Mud View Post
    In my opinion the shrinkage is also important
  16. #10
    Yes shrinking is definitely important. To my understanding it mostly results from elevated temperature while curing. I think the factors to minimize it is:
    Slow curing Epoxy
    Low temperature
    Adding a filler like silica/chalk
    But point 2 will result in a higher viscosity.
    And 3 in uneven surface
  1. Misumy linear rails
    By Boyan Silyavski in forum Linear & Rotary Motion
    Last Post: 11-05-2017, 03:46 PM
  2. FOR SALE: Minebea psu and linear rails
    By Iwant1 in forum Items For Sale
    Last Post: 15-07-2012, 10:55 PM
  3. Replies: 0
    Last Post: 04-12-2011, 03:23 PM
  4. THK linear bearing rails
    By Tonyel in forum Rails, Guideways & Bearings
    Last Post: 01-11-2008, 03:21 PM
