    Being in a hurry and not wanting to drop a big wad of cash yet, I decided on an eBay 6040 to get me started. I went for 800W spindle with the standard 1500W VFD and the blue controller box from hell, but I made sure it was a recent version with 3 separate M542 drivers rather than an all in one pcb.
    The long axis (labelled Y and that's probably what I'll call it) has one 1605 ballscrew driving the gantry, with SBR16 supported round rails. Cross axis and Z are unsupported 20mm and 12mm round rails.
    First worry was the low quality of the mounting of the 1605 screws, just a washer (or not) and a badly made (wonky) nyloc nut. I tightened it all up just a bit more than finger tight. The X drive is a bit graunchy at times, in one direction only. Any ideas on what that might be? corrosion of the bearings? badly made ballnut? I intend to take it apart and fiddle with the mechanical bits before I run it in anger.
    What sort of lubrication does a ballscrew need?
    Next problem was that on and off (mostly on) and for a prolonged period when it happens, x+ and z+ wouldn't jog after doing y+. but doing y- would make them work again. I swapped the X and Y leads at the control box, and the problem switched axes. Therefore the problem is inside the control box, either the BOB or the M542s. I will swap the M542s next and test the grounds. See if that helps or tells me more.
    Final thing fo rthe moment, how do I swap axis directions in Mach3 ? currently Z+ is down on my machine?
    I've checked the VFD setting and run the spindle up to speed. Not plumbed the pump yet. How long can I run the spindle without cooling?
  1. What is your opinion of the CNC 6040 Router Machine ?
    By John S in forum Chinese Machines
    Last Post: 30-11-2023, 10:58 AM
  2. New 6040 owner looking for advice from others with a chinese 6040/3040
    By itsmillertime in forum Machine Discussion
    Last Post: 14-10-2019, 08:30 AM
  3. Durability of a 6040 ?
    By jimbo_cnc in forum Machine Discussion
    Last Post: 11-08-2014, 01:37 AM
  4. Chinese 6040 CNC Router Advise Needed
    By Bob Hepple in forum Chinese Machines
    Last Post: 27-11-2013, 12:00 PM
  5. 6040 router
    By John S in forum Milling Machines, Builds & Conversions
    Last Post: 01-10-2012, 07:18 PM
