    Hi guys,
    Do you guys have some direction on needed Cabinet size?
    I need to harbour
    - Diy PSU
    - 24 vdc psu
    - 5v PSU
    - 4 or 5 882 drives
    - Terminals
    - Circuit breakers
    - Control bourd uccnc 300
    Some relais..
    Am i forgetting something..?
    VFD goes outside of the box
    Grtz Bert.
    It needs to be bigger than you first think.
    Things to consider; (I will probably have missed some out)
    You need to finalise the electrical drawing first, it's a MUST
    allowance in depth for the backplate
    layout to prevent interference of control wiring from power wiring
    trunking to route the wiring
    DIN rail to mount the components
    space from top and bottom of components to trunking (enough for crimp terminals and cable markers)
    ventilation fans, in and out of the cabinet
    filtration of incoming air to the cabinet (inside of cabinet should have positive pressure)
    space for door interlocked isolator
    space to allow for connection to drives (tuning interface cable)
    enough depth for door mounted components (so they are clear of other items in the cabinet)
    space for a row of terminals at the bottom where cables are glanded
    space for future expansion (another bob, etc.)
    consider using a Safety Relay such as Pilz or Preventa
    I had to draw mine out in a CAD program but the cabinet was still slightly too small.
    http://www.mycncuk.com/threads/6565-...6144#post56144
    http://www.mycncuk.com/threads/6565-...6651#post56651
    http://www.mycncuk.com/threads/6565-...2213#post52213
    It seem that information was unworthy of a response, so good luck with your panel.
  4. The Following User Says Thank You to EddyCurrent For This Useful Post:
  5. #4
    Lives in Plymouth, United Kingdom. Last Activity: 3 Hours Ago Has been a member for 9-10 years. Has a total post count of 1,730. Received thanks 295 times, giving thanks to others 11 times.
    I meant to reply but my original eBay order doesn't have the dimensions and I keep forgetting to measure it...
    However, from memory, I think it's 500x400x200. In that, I have a CSMIO motion controller, four stepper drivers, safety relay, stepper PSU, psu relay. On the inside of the door I have a 24V and a 5+12V PSU. Two 12V fans on one side blowing air in, across the stepper driver heatsink. It fits, but there isn't really any space spare and wiring is more difficult if space is tight. If I were doing it again, I would go a little bigger. Beat easy, if you have the bits, is to lay them out on the bench and see how much space they take up, allowing for things like internal cable guides.
    Don't know if that helps as it all depends on exactly what you are going to be installing.
  6. The Following User Says Thank You to Neale For This Useful Post:
  7. #5
    Good tip to get al the bits and make a layout.
    But at least 500x400.
    Ok...
    Thanks guys.
  8. #6
    No i am sorry Eddy... just busy at work..
    I have found this forum very informative with lots of nice people willing to share good information.
    Thanks for all the good information.
    Grtz Bert.
  9. #7
    Lives in East Lothian, United Kingdom. Last Activity: 5 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has been a member for 9-10 years. Has a total post count of 2,910. Received thanks 360 times, giving thanks to others 8 times.
    Far bigger than what you think you'll need!
    My smallest control box is the one used on my little digitiser (photos can be found at https://www.flickr.com/photos/mc_mtb...57646048305954). IIRC it's a 400x500x150, as I happened to have that size lying around. With that setup, I certainly wouldn't go any smaller, and if I was using separate stepper drivers/controller, I would of wanted something a bit bigger.
  10. #8
    Ok thx for the pictures.
    500x400 doesnt look that big any more...
    I will look at my options when i have the parts.
    Grtz Bert
  11. #9
    Good info in this thread!
    I always underestimate the number of connectors I'm going to need, for every project just not cnc one.
    Watching photos from others projects is a real good starting point!
    My controlcabinet will probably be 100x50x18cm
    But I will try to cram the pc and just maybe the vfd in there as well.
    I'm also thinking of dividing the cabinet internally with thin steel sheet to shield pc and another divide for vfd. These would be connected to star ground... good idea? :D
  12. The Following User Says Thank You to Nr1madman For This Useful Post:
  13. #10
    Well for the health of the vfd yes but i wonder if that weighs up to potential problems...
    Also it depends on what you are machining most. MDF will put dust in everywhere
    Vfd in cabinet with a proper air filter might work best.
    I am looking for twin door setup cabinets 400mmm high now... ip 55 or better... or put a good fan on it with filter to create positive pressure and keep dust out.
    Hope something turns up 2nd hand.
    I work in hvac stuff.. something will turn up...
    Grtz Bert
  14. The Following User Says Thank You to driftspin For This Useful Post:
  1. Controller Cabinet
    By cropwell in forum Workshop & Equipment
    Last Post: 19-12-2015, 02:23 PM
  2. Tool magazine access and the Siemens CNC Sinumerik controls
    By cossiegaz in forum Siemens (Sinumerik)
    Last Post: 05-11-2015, 10:14 PM
  3. FOR SALE: XYZ PRO 3000 with Prototrak MX2 controls
    By FarrerDesign in forum Items For Sale
    Last Post: 17-06-2013, 11:47 AM
  4. DRives and Controls 2012
    By georgetheforge in forum General Electronics
    Last Post: 02-04-2012, 02:51 PM
  5. Stepper shaft size and pulley bore size problem
