    Hi I was looking for Epoxy to level my linear rails. I came across Reckli Epoxy pb. It has a viscosity of 230 mPa/s. It's cheap 13€/11GBP per kg.
    Do you think it's worth a try?
    Thanks a lot
    Felixhttps://cloud.tapatalk.com/s/5cb75154...poxy_PB_en.pdf
    Sent from my MI 6X using Tapatalk
  2. The Following 2 Users Say Thank You to feldah For This Useful Post:
  3. #2
    Most of us use the West Epoxy system, which is quite common. The 105 resin with the 209 extra slow hardener is the way I'm going with mine - but it costs about 5-6x times the version you've posted.
    Theres a rather good discussion of the topic here:
    http://www.mycncuk.com/threads/8197-...-for-levelling
  4. The Following 3 Users Say Thank You to AndyUK For This Useful Post:
  5. #3
    Hey yes I know the thread. But the 105/209 has a way higher viscosity with 600.
    It just has a bit longer cure time which may give it a bit more time to settle
  6. The Following 2 Users Say Thank You to feldah For This Useful Post:
  7. #4
    On my routercnc YouTube channel I had a few goes at mixing and laying the West epoxy. You can see what is involved and how it turned out. Here is Episode 15
    https://youtu.be/Ax5Ib7GcTqE
    Also in Ep 17 and a few episodes later for the Y rails. This may help decide whether to go with the West system or not.
  8. The Following 3 Users Say Thank You to routercnc For This Useful Post:
  9. #5
    Yes I followed your episodes interested. But I wouldn't have heated the epoxy beforehand. West system recommends heating the surface rather then the epoxy. But I wouldn't do it at all as heating and cooling brings shrinking I would say.
    I was thinking to test my built channel with ethanol for leaks.
    I think I will give it a try with the epoxy I found it's nearly a third of viscosity. And price seems to be fair too
  10. The Following 2 Users Say Thank You to feldah For This Useful Post:
  11. #6
    Mud's Avatar
    Lives in Bristol, United Kingdom. Last Activity: 11-12-2020 Has been a member for 3-4 years. Has a total post count of 23. Received thanks 3 times, giving thanks to others 0 times.
    Easy Composites IN2 is also very thin and very slow. The quoted demould time of 24hrs is more like 36+ in my experience. Disclaimer: I have no experience using it for levelling things.
  12. The Following 2 Users Say Thank You to Mud For This Useful Post:
  13. #7
    Yes but still 600 compared to mine having 230
  14. #8
    Mud's Avatar
  15. #9
    Lives in Marple Stockport, United Kingdom. Last Activity: 16 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has been a member for 9-10 years. Has a total post count of 3,333. Received thanks 618 times, giving thanks to others 78 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    Quote Originally Posted by Mud View Post
    In my opinion the shrinkage is also important
  16. #10
    Yes shrinking is definitely important. To my understanding it mostly results from elevated temperature while curing. I think the factors to minimize it is:
    Slow curing Epoxy
    Low temperature
    Adding a filler like silica/chalk
    But point 2 will result in a higher viscosity.
    And 3 in uneven surface
  1. Misumy linear rails
    By Boyan Silyavski in forum Linear & Rotary Motion
    Last Post: 11-05-2017, 03:46 PM
  2. FOR SALE: Minebea psu and linear rails
    By Iwant1 in forum Items For Sale
    Last Post: 15-07-2012, 10:55 PM
  3. Replies: 0
    Last Post: 04-12-2011, 03:23 PM
  4. THK linear bearing rails
    By Tonyel in forum Rails, Guideways & Bearings
    Last Post: 01-11-2008, 03:21 PM
