Seig KX1 CNC Milling Machine
Attachment 11733
Hello I am selling our Seig KX1 milling machine, it's approximately two years old and has been used in the main for engraving brass and aluminium along with machining small parts in aluminium and engineering plastics. It is an excellent machine and we have now moved onto a slightly bigger machine and the space is needed so this little machine needs to go. The KX1 is in excellent condition and will come complete with a MT2 collet chuck and set of collets. You will need a Mach 3 license and compatible PC to operate this machine. Please contact me for further details.
£1500.00 ono.
Specification:
| End Milling Capacity |
10mm |
| Face Milling Capacity |
20mm |
| Drilling Capacity |
10mm |
| Effective Table Size |
400x145mm |
| Lubrication |
Press Button Oilers |
| Table Travel - X-Axis |
260mm |
| Table Travel - Y-Axis |
115mm |
| Head Travel - Z-Axis |
185mm |
| Head-Table Distance |
70-255mm |
| Ballscrew Size (Dia. x Pitch) |
12mm x 4mm |
| X-Axis Motor |
1.35Nm |
| Y-Axis Motor |
1.35Nm |
| Z-Axis Motor |
2.2Nm |
| Throat |
140mm |
| No. of T-Slots (Size) |
3 (8mm) |
| Positional Accuracy |
0.01mm |
| Spindle Taper |
MT2 |
| Spindle Motor |
500w Brushless DC Motor |
| Spindle Speed |
250-7000rpm |
| Max. Spindle Motor Torque |
1.8Nm @ 1500rpm |
| Power Requirements |
230v AC 50Hz |
| Overall Dimensions (w/d/h) |
630x630x630mm |
| Max. Space Required (w/d/h) |
910x630x730mm |
| Shipping Dimensions |
76x76x79cms |
| Weight (Net/Gross) |
86/120kg |
***PLEASE NOTE THAT THIS IS NOW SOLD, THANK YOU***
Re: Seig KX1 CNC Milling Machine
Skysurfer
Where are you?
TIA
We're near Bodmin in Cornwall
