    D2C's Avatar
    Lives in Lanivet, United Kingdom. Last Activity: 17-03-2014 Has been a member for 9-10 years. Has a total post count of 2.
Name:	2014-03-02 16.02.01.jpg
    Hello I am selling our Seig KX1 milling machine, it's approximately two years old and has been used in the main for engraving brass and aluminium along with machining small parts in aluminium and engineering plastics. It is an excellent machine and we have now moved onto a slightly bigger machine and the space is needed so this little machine needs to go. The KX1 is in excellent condition and will come complete with a MT2 collet chuck and set of collets. You will need a Mach 3 license and compatible PC to operate this machine. Please contact me for further details.
    £1500.00 ono.
    Specification:
    End Milling Capacity 10mm
    Face Milling Capacity 20mm
    Drilling Capacity 10mm
    Effective Table Size 400x145mm
    Lubrication Press Button Oilers
    Table Travel - X-Axis 260mm
    Table Travel - Y-Axis 115mm
    Head Travel - Z-Axis 185mm
    Head-Table Distance 70-255mm
    Ballscrew Size (Dia. x Pitch) 12mm x 4mm
    X-Axis Motor 1.35Nm
    Y-Axis Motor 1.35Nm
    Z-Axis Motor 2.2Nm
    Throat 140mm
    No. of T-Slots (Size) 3 (8mm)
    Positional Accuracy 0.01mm
    Spindle Taper MT2
    Spindle Motor 500w Brushless DC Motor
    Spindle Speed 250-7000rpm
    Max. Spindle Motor Torque 1.8Nm @ 1500rpm
    Power Requirements 230v AC 50Hz
    Overall Dimensions (w/d/h) 630x630x630mm
    Max. Space Required (w/d/h) 910x630x730mm
    Shipping Dimensions 76x76x79cms
    Weight (Net/Gross) 86/120kg
    ***PLEASE NOTE THAT THIS IS NOW SOLD, THANK YOU***
    Where are you?
    TIA
    D2C's Avatar
    Quote Originally Posted by Skysurfer View Post
    Where are you?
    TIA
    We're near Bodmin in Cornwall
  1. WANTED: cnc milling machine
    By bigred5765 in forum Items Wanted
    Last Post: 25-04-2014, 11:08 PM
  2. Seig C4 Lathe CNC conversion
    By njhussey in forum Sieg Lathes
    Last Post: 11-04-2014, 06:40 PM
  3. seig x3 R8 V MT3
    By dazza in forum Milling Machines, Builds & Conversions
    Last Post: 18-02-2014, 01:14 PM
  4. WANTED: X3 CNC milling machine
    By Nemo1966 in forum Items Wanted
    Last Post: 09-11-2013, 10:42 PM
  5. First CNC milling machine help
    By newtoid1986 in forum Milling Machines, Builds & Conversions
    Last Post: 05-09-2011, 10:06 PM
