2 Attachment(s)
		(Now found) 2 Inductive sensors
		I'm after two inductive sensors for my milling machine. They need to be the cylindrical type, so something similar to this:
http://www.mycncuk.com/attachment.ph...id=13880&stc=1
I don't mind if it's NPN/PNP or what voltage, size, colour ... anything that shape basically!
If someone would like to do a swap then I've got plenty of these.
http://www.mycncuk.com/attachment.ph...id=13881&stc=1
Thank you...
		Re: Wanted: 2 Inductive sensors
		Are these 4mm Dia or 4mm sensing distance
John
johnsattuk
John
 The latter I think, but either is fine for me as I'm yet to make the part which they'll mount upon.
		3 Attachment(s)
		Hi Jonathan
Don't have exactly what you want,  sent 6 to Australia a few months ago
Have a variety 4mm dia plain, M5 threaded, M12 threaded, M18 threaded.
The M12s are used but OK and still have a good length of lead on them.
I can send any/all of them for you to play with if you like
regards
John
http://www.mycncuk.com/attachment.ph...id=13882&stc=1http://www.mycncuk.com/attachment.ph...id=13883&stc=1http://www.mycncuk.com/attachment.ph...id=13884&stc=1
		I have got 5 LJ12A3-4-Z/BX  (4mm/NO/NPN) which you can have on a replace basis (you can order them from China) I am in Cropwell Bishop Nottinghamshire, so easy(ish) for you to collect if in a hurry. PM me if interested.
Rob
		2 Attachment(s)
		Have some reed switches that I have used in the past,  sometimes fit into small spaces more conveniently.
John
http://www.mycncuk.com/attachment.ph...id=13888&stc=1http://www.mycncuk.com/attachment.ph...id=13887&stc=1
