    I'm after two inductive sensors for my milling machine. They need to be the cylindrical type, so something similar to this:
    I don't mind if it's NPN/PNP or what voltage, size, colour ... anything that shape basically!
    If someone would like to do a swap then I've got plenty of these.
    Thank you...
ID:	13880   Click image for larger version.
Name:	high-quality-flat-type-inductive-proximity-switch-NPN-normally-open-metal-sensor-with-supply-vol.jpg
    Are these 4mm Dia or 4mm sensing distance
    John
    Quote Originally Posted by johnsattuk View Post
    John
    The latter I think, but either is fine for me as I'm yet to make the part which they'll mount upon.
    Hi Jonathan
    Don't have exactly what you want, sent 6 to Australia a few months ago
    Have a variety 4mm dia plain, M5 threaded, M12 threaded, M18 threaded.
    The M12s are used but OK and still have a good length of lead on them.
    I can send any/all of them for you to play with if you like
    regards
    John
ID:	13882   Click image for larger version.
ID:	13883   Click image for larger version.
    I have got 5 LJ12A3-4-Z/BX (4mm/NO/NPN) which you can have on a replace basis (you can order them from China) I am in Cropwell Bishop Nottinghamshire, so easy(ish) for you to collect if in a hurry. PM me if interested.
    Rob
    Have some reed switches that I have used in the past, sometimes fit into small spaces more conveniently.
    John
ID:	13888   Click image for larger version.
  1. FOR SALE: Proximity sensors
    Last Post: 13-09-2014, 08:02 AM
  2. Proximity Sensors / Mach3 not showing
    By dudz in forum General Electronics
    Last Post: 15-06-2013, 08:47 AM
  3. WANTED: Wanted taps & die
    By phill05 in forum Items Wanted
    Last Post: 28-11-2010, 01:27 PM
  4. Help wanted
    By ricey3 in forum Machine Discussion
    Last Post: 17-12-2009, 06:43 PM
  5. Proximity Sensors as Limit Switches ?
    Last Post: 03-10-2009, 07:04 PM
