Waiting on the uc300 eth motion controller and ucbb breakout Broad to be delivered for a uccnc upgrade,,, it also came with a uccnc licence,,,,,,,got an option for a new Hiteco hsk 63f spindle,,,,,,anyone using this type?
HSK63 is bit on the large side for a router but it will certainly do the job, thou tool holders are expensive compared to say BT40. For instance, I just looked on Cutwel site and HSK60F ER32 collet holder is £102. BT40 ER32 is £17.30.!
HSK is much stiffer but to be honest it will be wasted on a Chinese router so unless it's same or not much more money, then because of the much more expensive tool holder then I'd probably give it a miss because 10 tools, which sounds a lot but for ATC it's not, will cost £1K+ compared to £200 or less. BIG Difference.
I've noticed from some of your other machine builds that you are using a fixed BK12 bearing in both ends of the X-axis (don't know about Y-axis). What is the reason for that?
Also in this video, you are not using any floating bearing on the Z-axis. Is it not needed because of the very short Z-axis length?
I do this on all ball-screws longer than 1000mm on both X & Y. The reason is to lower ballscrew whip, 2 fixed bearings provides more support and also allow the screw to be pre-loaded with tension.
Not required on ball-screws less than 350mm.
Hi Jazz,,
I live in the US and I purchased a similar Chinese 4.5KW BT 30 ATC spindle.
I built my own CNC and after having several successes in manufacturing parts (For about two years now) I have decided to add an ATC to my machine.
The problem that I’m having is that I can hardly find any help on how to connect this item.
It cost about $2000 and I don’t want to short it or break it since there is no warranty for noobs like me.
I am not a professional CNCer and everything I’ve learned about it have been on YouTube from people like yourself. It is a hobby that I truly enjoy and hopefully I could someday earn a little bit of money from it, however for now, it is only a hobby.
Could it be possible that you can help me with my questions?
Any help will be greatly appreciated.
Sincerely José Ricardo
ATC Questions
Hi Jazz,
Thank you for your time.
My my questions revolve around The electrical connections and the pneumatic connections.
Power supply, Thermal, Fan
The manual says:
9 pin plug
1. Thermal: 1, 5. What wire do I connect here? From where?
2. Fan: 3 Black,9 Red. What wire do I connect here? From where?
3. Power supply: 4 Red U,6 Black V,8 Blue W. GOT IT VFD.
4. Ground: 2 Yellow,Green. GOT IT from VFD.
Proximity switch
Switch button
11 Pin Plug
Hanging knife: 1 5 Red
Unloading knife: 2 11 Red
0V: 6 Blue 7 Blue
24V: Brown 8 Blue
5. What is hanging knife: 1? What do I connect here? From where?
6. What is unloading knife:2? What do I connect here? From where?
7. 0V: 6 Blue. What do I connect here? From where?
8. 24V: Brown What do I connect here? From where?
Do I get the 24V from outside source?
Which Pin is this? What does it do?
Switch button (it’s a little red button with two wires NC (I can only assume is to engage solenoid solenoid to drop the tool) What does it do?
9. 5 Red. What do I connect here?
10. 11 Red. What do I connect here?
11. 7 Blue. What do I connect here?
8 Blue. What do I connect here?
I contacted the company that sold me the spindle but you know, Chinese. They just basically told me to find my own engineer.
In reference to the pneumatics, I have one 1/4” connection and two 4mm connections. I’m not sure where these go.
Again, thanks a lot For any help you can provide on this.
Jose Ricardo
