Quote Originally Posted by NordicCnc View Post
I see. How do you apply the pre-load with 2 fixed bearings? I thought the common way to do it was using a double ball-nut.
Skickat från min SM-A530F via Tapatalk
You didn't read it correctly, I said to preload the screw with tension. I'm not preloading the ball nut I'm just putting the screws under tension so it doesn't whip.
