Re: List of CAD/CAM Software
Anybody tried these, free and from Autocad, you have to take a look, quite unbelievable really.
http://www.123dapp.com/create
Also this; http://www.wintopo.com/
Free version available, Raster to Vector, exports to DXF, I can confirm it works great with Cambam.
routercnc
however, it does lack features such as roughing out cuts. You would need to create an offset surface in your CAD programme and run that one first.
Can't you just lie to the software about cutter OD and cutter length (or Z zero) to make the job much simpler?
Check this one out, free but you have to revisit each 60 days, CAM and simulator
http://cncsimulator.info/
DOS based "8 axis CNC interpreter", alternative to Mach3 ?
http://www.dakeng.com/turbo.html
Attachment 13307
G-code ripper now has an auto probe function for cutting 2D designs on uneven surfaces (like the mouse in the picture).
EddyCurrent
multi axis CAM - it's open source
I looked at a video...
He drew a back and forth XY tool path in 2D
He projected it down on to the surface of a sphere to get 2.5D
He turned the tool so it stayed perpendicular to the sphere surface to get 4.5D
He ran it in software emulation, well it seemed to do something
He exported part of a G code using cut and paste.
I don't think you have to be a geek to see this is somehow lacking.
Robin Hewitt
Yes, being open source it's lacking in cost. But in any case I like to keep adding to this thread which I think is useful for eveyone.
CNCtoolkit has been mentioned on this forum before. I've played with it a bit and it is quite capable - though I've not cut anything with the code it generates. This member on youtube however has made some worthwhile toolpaths using it:
https://www.youtube.com/watch?v=VEDiVESUeNU
Mad Professor
Can we add Ucancam , Having just been updated to V10 and priced around £120/£160 for the standard version or £320/£400 for the Pro version (Pro offers full 3D machining support etc)
It is usually given with Chinese machines if you want something better than the 'copied' type 3 and Artcam.
On the up side, the list of features are high, on the down side, some of the English can be quite Chinglish.
"NC Corrector v4.0, a free editor visualizer programs for CNC milling machines (G-code)."
http://www.nc-corrector.inf.ua/index_EN.htm
I'd like to add my program, JointCAM to the list. Creates g-code for traditional woodworking joints. It's still in development, but is avaiable now.
http://g-forcecnc.com/jointcam.html
Pity about the name;
"OpenSCAM is an Open-Source software which simulates 3-axis CNC milling or engraving. It is a fast, flexible and user friendly simulation software for the DIY and Open-Source community. OpenSCAM works on Linux, OS-X and Windows. "
http://openscam.com/
I don't know if this option is available in the UK, but Autodesk has an introductory offer for Fusion 360 (CAD and CAM) that get's you the full $1200/year package for $300/year, for life.
http://fusion360.autodesk.com/pricing
I've never used it, but I'm seriously considering it.
I had hoped to one day purchaser a full seat of AutoCAD. But, Autodesk is going subscription only next year for all their products, and this is a great deal.
[QUOTE=Ger21;63639]I don't know if this option is available in the UK, but Autodesk has an introductory offer for Fusion 360 (CAD and CAM) that get's you the full $1200/year package for $300/year, for life.
QUOTE]
you can also get it free or a slightly limited version that's cad and cam by using the startup or student option its not a trial version.
I installed it earlier and all seems to work fine.
if anyones interested this video covers a bit about the software and tells how to install it in the comments.
https://www.youtube.com/watch?v=VzqXo0d0W8s
Mad Professor , please update the list at the beginning withthe links all provide
Nobody mentioned Rhino,which i believe may be the best program money wise/feature wise. In real life most of the people i know of, use Rhino+some integrated cam. That and Solidworks are the most popular i have seen at machining shops or small companies. Solid edge seems the most popular here for designing products and Autocad for architectural and interior design.
silyavski
I think you are correct, it's what I use now.
Hi, if you register with your local school/college then Auto Desk will let you have a licence for 3 years to use all their software for free as long as you are not using it for business use.
Looking for a suitable CAM software, of coarse no one gives any price information without registering or mailing them all.
.... Anyone with some recent quotes or prices lists? Looking at 3 axis Mill/router.
CAD is latest SolidEdge ST7, the integrated offering, Cam Express, from Semens is about 4K+
I'm not worried if it's not free, but I'd like to test the water before one day before haggling a deal on the integrated option.
Magic CAD/CAM Sweet consisting of DesignCAD 3D MAX and ContourCAM
I should like to suggest the Magic CAD/CAM Sweet consisting of DesignCAD 3D MAX and ContourCAM, a complete 2D drafting and 3D solid modeling CAD/CAM combo @ £129.95.
It's one of the easiest systems to learn and use, with a wealth of features, and you can download and use it for free for 15 days.
You may learn more about it here: http://www.magiccadcam.co.uk/
Autodesk Fusion 360 looks amazing and quite easy to learn from a complete novice perspective. Free and fully functioning for hobbyists and startups. Computer died yesterday so I'll get it when I get a new poota.
I had been learning CAD with Onshape which was pretty easy also but doesn't have integrated CAM. Am looking forward to playing with Fusion 360.
Clayt
I've just started messing with Fusion 360 - looking good so far although the design/modelling side is a little awkward in places due to the AutoCAD heritage (lots of hidden key press shortcuts and non-standard modifiers that probably go back to the DOS days) and my own lack of knowledge especially in organic shape modelling i.e I'm still at the lower end of the learning curve.
The included CAM looks really good with 2D and 3D both having "Adaptive/HSM" options, although along with many CAM packages its a case of setting various wide parameters and hoping the results come out the way you expect, but again that's probably due to only just starting with it.
I will have a couple of videos going up soon when I get the time to try out some of the toolpaths I've generated and see how they go.
As someone who's used AutoCAD daily for nearly 20 years, I don't think there's anything in Fusion even remotely related to AutoCAD.
As for the shortcuts keys, there's a list of shortcuts on the Fusion 360 Blog.
http://forums.autodesk.com/t5/post-y...s/td-p/5831660
I'm not sure if its been mentioned but I have just found OnShape, it is a free cloud based cad package, I have not had a chance to play with it yet but thought I'd mention it while it was stil fresh in my mind.
Cheers, Charlie
I've been playing with both OnShape and Fusion 360 recently. Previously I've used things like TurboCAD for 2D drawing and although I've tried using the 3D features, I've found it very difficult to use. These two new tools are a breath of fresh air. I'm sure that long-term professional users will know all this already, but if you've never tried it, the sketch-and-extrude, parameter-based approach makes things much easier to draw and much easier to modify and update. On balance, OnShape is probably the easier to use as they have worked hard at simplifying the user interface while F360 is a better established and more powerful tool. F360 also has the "sculpt" tools for more fluid shapes (might be what Washout was referring to) although I've stuck to just the straightforward geometric tools so far. It's been useful for both mechanical engineering type drawings (my new router is being drawn in F360 as it gets built) and for models for 3D printing.
It's difficult to describe the difference in approach between conventional 2D CAD and these newer applications, but it's a bit like the difference between a power-assisted old-fashioned drawing board, and the ability to scribble on the back of an envelope, add a few dimensions, and watch the 3D structure appear in all its glory. Hit a couple of buttons and 3D objects appear as a set of 2D drawings, ready for manufacture. Can't believe that applications like this are available free to the hobbyist.
Thanks for that link Gerry - that list is most useful and perhaps some qualifying statements are in order:
I should have said AutoDesk rather than AutoCAD perhaps ;-) - Its not big deal things, but more from a non-CAD user's perspective, stuff that you take for granted in "normal" windows programs that don't always translate well e.g. reversed zoom on middle mouse wheel (can change in options) and selecting multiple objects using shift rather than ctrl to name a couple. Whilst they are not game breaking in themselves (other CAD/CAM uses similar) can be a little tiresome to start with.
As Neale pointed out the T-Spline sculpt tools are a little unpredictable and especially as I was trying to work out a smooth multi-axis blend between two parametric drawn bodies (guitar headstock to neck and heel to neck transitions). No matter what I tried I couldn't get them to match up correctly using the functions provided in the t-spline sculpt and had to resort to some funky lofting and then merge/intersecting to get something close I can then sand to shape after cutting.
I fully admit that these are probably down to my inexperience with the software and maybe I'm expecting too much and too soon.
Similarly the CAM side is wonderfully featured and I've just cut my first test in plywood of an adaptive clearing routine before going onto Aluminium, which ran fine although it needs some tweaking. I do have an issue at the moment where I have an irregular shape (guitar neck) that I am trying to do something simple like a cut out pass, once all the flashy 2D and 3D shaping stuff has run and for the life of me I can't seem to work out how to just select the outline of the shape, as Fusion 360 keeps selecting faces which are under all the nicely 3D'ed stuff above it - like I said it will likely be some option I've missed, but its strange it doesn't just have that for a 2D contour operation from the get go....
I'm definitely going to persevere though, as the advantages of having combined CAD and CAM (and very good examples at that) in terms of being able to change things in the model and have that change flow through to the CAM can't be underestimated. I also appreciate that documentation and application refinement using "in house" resources for a "free" application is not very cost effective and Autodesk are taking a similar approach to Microsoft and Windows 10 in this instance.
Given Fusion 360 is likely to become very popular maybe a separate forum area would be best rather than clogging up this thread, as I'd love to share experiences with other Fusion 360 users (hint, hint Lee ;-) )
+1 for a Fusion360 dedicated area.
As I have posted a few years ago http://www.ekits.eu/PROCNCDraw/ is an update for very simple software to cut 2d parts. Also it can convert gerber code to g file for milling PCBs. Demo is fully functional but it accuracy is low. But it is absolutely usable in many cases.
Thanks Dean
I like it and price is affordable - hobby use
"GatorCAM for CNC" to the list.
Instructions to download:
https://youtu.be/hqyPzCKGUQc
Download here:
https://sites.google.com/view/gatorcam/home
Easy-to-select regions for tooling operations.
1-click selection can select many objects without the need to select and reapply tooling operations for every object.
Automatic "inside" detection.
Nested objects detection.
Optimal Tool Paths : less CNC wasted movement from one side of the work-piece to the other.
Tabs to hold down cutouts.
Inset, and finishing passes.
Pockets, grooves, profiles, vbit engraving.
Easy to use. Create GCode with less fuss.
Using more than 1 tool bit automatically creates separate GCode files (for manually changing the tool bit).
an Automatic Tool Change (ATC) GCode file is also created.
No hidden settings. Easy to edit: speeds, tool bits, step down, tab height, origin etc.
Not Cloud-based. No internet needed. No monthly fees/subscription. Not expensive (yet). Free upgrades.
https://sites.google.com/view/gatorcam/whats-new
https://sites.google.com/view/gatorcam/faqs?authuser=0
https://sites.google.com/view/gatorc...ons?authuser=0
My dedicated YouTube channel:
https://youtube.com/@gatorcamforcnc
Okay, hello everyone.
I hope i'm in the correct forum here (moderator, please move it to the correct one if i'm not).
I have used hobby cnc machines, with free gerber files but now I'd like to draw my own and cut them out on my Mach3 machine (approc 80 x 60 cm cutting area).
What software is out there that will let me do my own designs?
Something REALLY simple is all that is needed, I don't need or want any fancy gimmicks! I don't mind paying a reasonable (for hobby use) fee for the software.
Thanks.
There's a list of some here; https://wifitalents.com/best/gerber-pcb-software/
I've always thought KiCad was a good one, it's free open source but might take a bit of learning.
I’m working on an open-source project called PureCutCNC, and I just pushed version 0.0.2. It is still in the very early stages, but I’m excited to keep the momentum going.
The goal is to create a clean, accessible CNC control interface. This update focuses on editing functionality, new and improved operations, path optimization, improved DXF/SVG import, UI improvements, user guide and quick start.
I’m doing this as a passion project, so if you have a moment to look at the documentation or the application, I’d love to hear your thoughts.
Browser version is the easiest to start with the app. Preview of the desktop versions is also available in the downloads section.
Project site: https://purecutcnc.github.io
Thanks for looking!
EddyCurrent
Many thanks. Something to look into when I next get a chance.
SteveNotlob
Thanks.
Try PureCutCNC https://purecutcnc.github.io
It runs in a browser or as a desktop application. Free and no registration required.
Disclaimer: PureCutCNC is my own Open-source project. Feedback will be appreciated.
