Page 5 of 8 FirstFirst ... 34567 ... LastLast
  1. #41
    Anybody tried these, free and from Autocad, you have to take a look, quite unbelievable really.
    http://www.123dapp.com/create
    Also this; http://www.wintopo.com/
    Free version available, Raster to Vector, exports to DXF, I can confirm it works great with Cambam.
  2. #42
    however, it does lack features such as roughing out cuts. You would need to create an offset surface in your CAD programme and run that one first.
    Can't you just lie to the software about cutter OD and cutter length (or Z zero) to make the job much simpler?
  3. #43
    Check this one out, free but you have to revisit each 60 days, CAM and simulator
    http://cncsimulator.info/
  4. #44
    DOS based "8 axis CNC interpreter", alternative to Mach3 ?
    http://www.dakeng.com/turbo.html
  5. #45
    NB70's Avatar
    Lives in Swansea, United Kingdom. Last Activity: 02-07-2025 Has been a member for 9-10 years. Has a total post count of 61. Received thanks 10 times, giving thanks to others 9 times.
    G-code ripper now has an auto probe function for cutting 2D designs on uneven surfaces (like the mouse in the picture).
  6. #46
    multi axis CAM - it's open source
    http://www.cnc-toolkit.com/
    http://www.youtube.com/user/cnctoolkit/videos
    you might need this too, cnc-toolkit is a plugin
    http://www.turbosquid.com/Gmax
  7. #47
    I looked at a video...
    He drew a back and forth XY tool path in 2D
    He projected it down on to the surface of a sphere to get 2.5D
    He turned the tool so it stayed perpendicular to the sphere surface to get 4.5D
    He ran it in software emulation, well it seemed to do something
    He exported part of a G code using cut and paste.
    I don't think you have to be a geek to see this is somehow lacking.
  8. #48
    Yes, being open source it's lacking in cost. But in any case I like to keep adding to this thread which I think is useful for eveyone.
  9. #49
    CNCtoolkit has been mentioned on this forum before. I've played with it a bit and it is quite capable - though I've not cut anything with the code it generates. This member on youtube however has made some worthwhile toolpaths using it:
  10. #50
    Quote Originally Posted by Mad Professor View Post
    Good day all.
    Quite often I see posts regarding what CAD or CAM software is out there, so I was thinking about making a list of known CAD / CAM Software.
    Here are the following I know off the top of my head.
    Alibre Design
    AutoCAD
    CamBam
    BobCAD/CAM
    Dolphin CAD/CAM
    Draftsight
    FreeMILL
    Inventorcam
    MasterCAM
    Sheetcam
    Sketchup
    SolidCAM
    SolidWorks
    SurfCAM
    Vectric
    I know most are out of the price range for a hobbyist.
    It would be nice if we could make up a full listing of the software out there, what it supports and price ranges.
    Thanks for your time.
    Best Regards.
    Can we add Ucancam , Having just been updated to V10 and priced around £120/£160 for the standard version or £320/£400 for the Pro version (Pro offers full 3D machining support etc)
    It is usually given with Chinese machines if you want something better than the 'copied' type 3 and Artcam.
    On the up side, the list of features are high, on the down side, some of the English can be quite Chinglish.
  1. Replies: 2
  2. CNC machinist: Most hated job list
    By Robin Hewitt in forum General Discussion
    Last Post: 27-08-2011, 01:40 PM
  3. Which Software
    By Ricardoco in forum CAD & CAM Software
    Last Post: 12-01-2011, 04:43 PM
  4. BobCad 80% off list
    By Robin Hewitt in forum BobCAD-CAM
    Last Post: 06-08-2009, 04:25 PM
