Re: Advice on buying servos.
There are a few reasons, but this one normally gives you an indication.
Ok, lets say you have a machine with 8 axis and each axis needs a servo, that is not too large.
you can get 8 AC servo motors and driver and you will be paying more because each driver has its own power supply.
with the DC option, you will have 8 DC servo drivers and a large power supply.
Also DC servo motors are typically low voltage DC, so the current is higher, so typically the motors dont go too big (under a KW)
Personally, i would not even consider a DC servo system, unless you know why you need it. AN ac servo system is typically a better option.
Agathon
OK, that's a very concise reply, but why buy a DC over and AC and vice versa?
Gary
Right, so AC servo drivers aren't typically 240vac SP input then and need a step-down transformer?
No, AC is AC, regardless of the voltage.
Typically single phase goes up to about 1.5KW
For a hobby machine, its unlikely you will need anything that big.
Even a mill like Bridgeport MDI /Interact can use 750W easily.
Agathon
Gary
OK, so just to be clear. A 400W AC servo motor would typically be coupled to a driver powered by AC at a voltage less than 240v? So is the power supply simply a step-down transformer or is there more to it?
it totally depends on what the bus voltage of the motor is.
To make it easy, if and when you buy them get a matched pair with cables, or talk directly to the company and get advise on what they suggest for the application.
Gary
Thanks - I'll email you in the next few days.
Gary
Me too. And honestly valuing my time i will not consider separate PSU but a pure plug and play system.
No, most of the currently available 400w AC servos are 220-240V
Ger21
Nice.
What do you think of this: http://www.ebay.co.uk/itm/Samsung-RS...-/282340382590
Might it be suitable for my app or am I barking up the wrong tree?
