Thread: Advice on buying servos.
There are a few reasons, but this one normally gives you an indication.
Ok, lets say you have a machine with 8 axis and each axis needs a servo, that is not too large.
you can get 8 AC servo motors and driver and you will be paying more because each driver has its own power supply.
with the DC option, you will have 8 DC servo drivers and a large power supply.
Also DC servo motors are typically low voltage DC, so the current is higher, so typically the motors dont go too big (under a KW)
Personally, i would not even consider a DC servo system, unless you know why you need it. AN ac servo system is typically a better option.
Visit Us: www.automationshop.co.uk
10-07-2017 #2
10-07-2017 #3Visit Us: www.automationshop.co.uk
10-07-2017 #4
10-07-2017 #5
it totally depends on what the bus voltage of the motor is.
To make it easy, if and when you buy them get a matched pair with cables, or talk directly to the company and get advise on what they suggest for the application.Visit Us: www.automationshop.co.uk
10-07-2017 #6
10-07-2017 #7
10-07-2017 #8No, most of the currently available 400w AC servos are 220-240VOK, so just to be clear. A 400W AC servo motor would typically be coupled to a driver powered by AC at a voltage less than 240v?Gerry
UCCNC 2022 Screenset
Mach3 2010 Screenset
10-07-2017 #9
15-07-2017 #10
What do you think of this: http://www.ebay.co.uk/itm/Samsung-RS...-/282340382590
Might it be suitable for my app or am I barking up the wrong tree?
CS-LAB AC-servos + SIMdrive
By blim in forum Stepper & Servo MotorsReplies: 0Last Post: 20-02-2017, 12:52 PM -
Novice- need buying advice
By davespg996 in forum New Member IntroductionsReplies: 1Last Post: 09-02-2017, 11:12 AM -
Advice on Buying a Benchtop CNC
By Richb in forum Marketplace DiscussionReplies: 12Last Post: 27-06-2016, 06:43 PM -
Mitsubushi Servos
By Chaz in forum General ElectronicsReplies: 0Last Post: 24-04-2016, 08:08 PM -
Machine Buying advice
By jrob3rts in forum Marketplace DiscussionReplies: 0Last Post: 17-09-2010, 04:59 PM
