Anything can bend, but you don't necessarily notice until you start chasing those last few elusive microns :smile:
Robin,
Have you any pictures of the mod you did to the gib strips?
Ant
Just had a look at the pictures. Very interesting. Did you notch the gibbs or did it come already notched? Mine you just push on the end. How does yours maintain rigidity? You have the screw into the casting then the stud in the top how does the adjustment work? Can't tell from photos.
The Major and Minor have the notch and a bolt with a very wide head on it. The bolt head fits in the notch and moves the Gibb. If don't have the notch you must have a different system and my modification won't help.
Ant take out your jib and post a photo here to be sure.
But you may have a screw at each end of the jib.
If that is the case and your jibs are loose then to tighten you backoff the screw at the small end of the jib and tighten the screw at the large end of the jib. To be working correctly both screws will be tight locking the jib in the correct position.
Phil
Sent from my HTC Desire using Tapatalk
Will do. They are two screw type. But I will get some photos.
I replaced the ball screw in the machine now. I had Zapp Automation machine a "custom" ball screw for me which was a great job. Fitted like a dream.
I posted a video of my test on the machine.
http://www.youtube.com/watch?v=aQblxA38q5w
Now I have a problem which I'm not to sure how to sort out. Positional accuracy is pretty good. I machined a test part but I'm a little out. I'm guessing the backlash compensation will sort it out but I'm not sure how to ensure I get it right. What procedure should I use to see how much backlash I should compensate for?
Attachment 3824Attachment 3825Attachment 3826Attachment 3828
Attachment 3827
