  1. #21
    Quote Originally Posted by M250cnc View Post
    The column is made from cast iron, and cast iron does not bend. When you say deepening in what axis is it deepening the cut.
    Anything can bend, but you don't necessarily notice until you start chasing those last few elusive microns
  2. #22
    Very true but IF say you had a sloppy quill on your machine then the bending would come from that rather than very hard to bend cast iron.:naughty:
    Phil
  3. #23
    Indubitably
  4. #24
    Robin,
    Have you any pictures of the mod you did to the gib strips?
    Ant
  5. #25
    Quote Originally Posted by antsals View Post
    Try my Warco Major build log, reply #61
  6. #26
    Just had a look at the pictures. Very interesting. Did you notch the gibbs or did it come already notched? Mine you just push on the end. How does yours maintain rigidity? You have the screw into the casting then the stud in the top how does the adjustment work? Can't tell from photos.
  7. #27
    The Major and Minor have the notch and a bolt with a very wide head on it. The bolt head fits in the notch and moves the Gibb. If don't have the notch you must have a different system and my modification won't help.
  8. #28
    Ant take out your jib and post a photo here to be sure.
    But you may have a screw at each end of the jib.
    If that is the case and your jibs are loose then to tighten you backoff the screw at the small end of the jib and tighten the screw at the large end of the jib. To be working correctly both screws will be tight locking the jib in the correct position.
    Phil
    Sent from my HTC Desire using Tapatalk
  9. #29
    Will do. They are two screw type. But I will get some photos.
  10. #30
    I replaced the ball screw in the machine now. I had Zapp Automation machine a "custom" ball screw for me which was a great job. Fitted like a dream.
    I posted a video of my test on the machine.
    Now I have a problem which I'm not to sure how to sort out. Positional accuracy is pretty good. I machined a test part but I'm a little out. I'm guessing the backlash compensation will sort it out but I'm not sure how to ensure I get it right. What procedure should I use to see how much backlash I should compensate for?
ID:	3824Click image for larger version.
ID:	3825Click image for larger version.
ID:	3826Click image for larger version.
  1. Warco WM16 Mill - Conversion to AC motor with VFD
    Last Post: 10-02-2022, 07:41 PM
  2. CNC Turret Mill range
    By newtoid1986 in forum Milling Machines, Builds & Conversions
    Last Post: 28-11-2011, 07:23 PM
  3. Warco WM16 Conversion
    Last Post: 25-03-2011, 09:32 PM
  4. Warco mini mill cnc conversion
    By buster in forum Milling Machines, Builds & Conversions
    Last Post: 20-03-2011, 07:48 PM
  5. CONVERSION: Buget Warco Major 5 axis conversion
    By Tweaky in forum Conversion Build Logs
    Last Post: 07-10-2010, 04:26 PM
