Re: Hello from Grenoble
I think I’ve managed to confuse you, I mentioned the 0-10v controller to support easy integration with the existing bldc motor controller provided by the Sx2.7.
The separate case for me is, having blown the controller I’ve replaced that with a servo and controller, and the controller could take 0-10v speed demand from a BoB, for sure. Although I choose to use step/dir signaling instead. Same end result though, easy integration with UCCNC
Ok,
Seems very good info here.
Onestly, I'm falling behind of what you've achieved so far to CNC it!
But I'll be very interested to see if you have made some kind of reporting videos or photos on it.
Hi Jaket,
you said: "Clutch: Offers the freedom to move the table by handwheel or powerfeed."
That's a handy solution to keep the mill as original!
Wonder if you can still run this setup without the need of a mecanical clutch...maybe electronics system?
