Just a quick update...
John repaired the AXBB for me by replacing the faulty Fet. It's all back up and running now. Cheers guys and especially John.
Sent from my SM-G920F using Tapatalk
If the FET blew due to back EMF from the relay coil, then it's a bit naughty as the AXBB-E manual shows a direct connection with no added clamp diode :suspicion: Funny, I was just about to email Balazs to ask whether such diodes were included on the board, I'll let you know what he says.
I have no idea [emoji848] i have checked the wiring and all looks ok although I have removed all the switch light outputs just in case that was the cause...[emoji848] I've protected it now with a 7001n diode across the relay and a 27ohm resistor on the charge pump output so hopefully it will be ok now.
It is not easy to tell what the problem was
a case of no fault found that could of damaged the FET
As the relay worked when the wire from the AXBB output was connected to the -24V supply
you can only suspect either there was an intermittent short connecting the +24V supply to the AXBB output
or
an intermittent open circuit that generated a sustained back emf that over stressed the diode in side of the NTR5198NL-D FET
or may be it was a faulty FET
John
PS
the diode added across the relay coil and a 27ohm resistor in series with the relay coil
will help to protect the AXBB output
the resistor limiting the current if coil is short circuited
and the diode clamping the back emf when the relay is switched off
Hi Voicecoil
The diagram in post 40 shows the signal path through the circuit after the HCPL-2631 opto isolators
the only diode is within the NTR5198NL-D FET
hence my comment in post 30
“Its a pity they had not used a DIL (dual in line ) octal transistor array like the ULN2803
or a new FET array
like the Toshiba TB D62381A series DMOS transistor array
that would enable the user to plug in a replacement “
the Gecko G540 has the same issue with a FET that's soldered in
John
Well in that case the manual really should show a clamp diode in parallel with the relay coil IMHO. The intrinsic body diode in the FET will be sod-all use for a coil that's connected between the output and +24 as it'll shoot a long way positive when the FET switches off and over-voltage it in the process. The great thing about drivers like the ULN2803 you mentioned is that they have the clamp diodes built into the chip which makes it a lot less likely that they'll blow. I'll be adding some diodes to all my relay outputs tomorrow.
A little late, but just wanted to clarify.Quote:
it seems strange that the software will allow me to choose any output for the charge pump though.
Yes, you can assign the charge pump signal to any output. But the charge pump signal is a PWM signal. Only Port 1 Pin 1 has circuitry to convert the PWM signal to an on/off state. If you assign the charge pump to a different output, you'll just get the PWM signal on that output, which will not switch a relay.
Of course... you may want to use the PWM charge-pump output to control an existing, external charge-pump.
Hi Gerry
Thank you for the missing detail
that makes sense of the test results when Charlie tried using another output
John
