Re: Machine keeps stopping?
Hi Kev,
This is a common problem for a few with an OmniCNC machine using a cdxhctech.com card, as I understand its related to USB and is caused by signal level, interference and earthing problems, this is also common for other brands of chinese USB interfaces.
The fix given a few times was to look at all earth's and make sure they are good and well connected, you can connect an earth to the PE of the spindle VFD if it is missing one and also look into the spindle and see if that has a good earth connection.
Before you go looking at all that though, you can start Mach3 and when presented with the option for connecting to the machine, so this would be the printer port, xpod stuff, at the bottom left of that screen there is an option that read to the effect of "dont ask me this again", choose that as well and give the machine another test run and see what happens.
Since choosing that option it has fixed the problem for people and been passed as a bug in the software, however you should check the earthing as well.
Let us know what happens next!
Hi Lee thank you very much for the reply.
This is a problem I've had since purchasing the machine about 18 months ago and now has returned.
I have earth the VFD to the metal enclosure, and then taken a second earth from another suitable point in the enclosure to a mains earth.
I have also ran an earth for the main frame of the CNC again to a main earth.
I’ve tested the spindle body with main frame of the machine for continuity and that’s fine.
I’m not sure if i should completely uninstall Mach3 and reinstall.
I’m a little reluctant to use machine for any projects ata the moment just in case it crashes
piper1
Ok well if your happy all is well with the earthing give the "dont ask me this again" option a try, as your describing it as an intermittent problem, plus you've added the MDF bed, I feel that it maybe a signal wire has come close to a power wire and noise is getting into the signal wire.
How isolated is the USB wire from one to the other?
To be honest Lee i think i should invest in a decent USB cable, i had to buy an extended on to reach the computer and didn’t pay attention to it needing ferrite rings on either end.
The USB cable is pretty exposed to several other cables between both the machine and computer, but i will move it to minimise any interference.
Lee do you know of anyone within the North west that does service router machine?
Thank you
Kev
Remember that too many earths may result in a ground loop. so take the earth to just one place (think star point) I there a ground between the pc and controller try a different usb lead.
Thanks Clive I'm just searching for a new USB lead now.
Will also look up star point grounding.
piper1
Thank you
Kev
I new it ;-)
A decent USB cable can help but if you can move it away from the other cables you may not need a new one, remember you've had your machine working fine at times, this tells us the setup has potential.
No sorry I dont but we have members all over the UK so you could put up a request in the Projects, Jobs & Requests forum.
Did a couple of test runs this afternoon, one with the spindle running and one without
Both ran the exact program, same length of time etc and not not a glitch in sight.
Both test ran flawlessly, i was so made up.
The only thing i did in the hope to remedy the fault with the machine stopping during programs was to move the USB cable away from any other possible interference's (cables).
Going to run the same program again tomorrow with the machine cutting this time , fingers crossed.
Thank you for the advise Lee.
I think you said you said that you had an extension to the usb lead if so buy a new lead long enough the shorter the better. make sure it is a good quality one.
With an extension you are creating another joint
Going to order one on the morning Clive, cheers.
Keeping my fingers crossed for tomorrows test run.
piper1
Sweeeet!
Hopfully the next test works fine, Clive is right as well grab yourself a nice USB cable about the right length, you dont need to spend crazy money getting some gold plated, braided bad boy, something like this should do: Hama USB Cable Blue 5m
Keep us posted its nice to know when something gets fixed :)
Ran the third test this afternoon to confirm that everything was still working ok and it ran perfectly without missing a beat.
Still using the old USB cable until the new one arrive.
Managed to sort out a couple of ferrite rings so added them to the old cable.
Thank you so much to everyone for all the support i received i really do appreciate it.
Kev
Glad you got it working
piper1
Kev
Your more than welcome, I'm pleased you got it sorted out.
