Mach 3 Tool Change Location Help?
Hello Guys,
I am after a bit of guidance regarding the tool change location function within MACH 3.
I have configured my Auto Tool Zero and it is running lovely however I am unsure how to set up a certain location where it will go to before it does every tool change?
If someone would be able to help me with this it would be greatly appreciated.
Regards,
Tim
Re: Mach 3 Tool Change Location Help?
You need to modify the M6start and M6end macros.
I've not used Mach 3 for a few years, so it'll probably be better searching over on the mach forums.
The gcode you need is G28. This takes the machine to s predefined position, which could be your tool change position. You set the position (using machine coordinates) in one of the Mach3 configuration screens, although I can't remember which one off the top of my head. As m_c says, you can then incorporate this code into your M6start macro so that as part of the tool change operation, the machine will go to the tool change position. On my machine, I also have a fixed touch plate set into the bed at this point so I can do a "second operation" tool height setting without having to jog the tool again. When you hit "run" the M6end macro is called which by default takes the machine back to where it was when the m6 tool change started.
Neale
I thought it was as easy as adding some more vbscript into my Auto Tool Zero script already? Would this work OR does it have to be done within the M6START & END Macro?
Tim
Can you explain exactly what you are trying to do? Everyone has their own way of working and I'm not quite sure what you're looking for.
For example, my tool change code moves the tool to tool change position, waits until I hit Run, then goes back to where it started and carries on. While the tool is at the tool change position, I can choose to use one of the tool-height setting options I have written or not - they are not built-in to the tool-change macros themselves. That suits the way I work, but might not be right for everyone.
Neale,
When I'm running our GCODE to produce one of our units it had four cuts in total. I would like it to go to a certain position WHEN a tool change it needed then I press auto tool zero it hits my wireless probe (Which will be in a fixed location) zero's its self out and then returns to the next cutting position.
Hope this makes sense to you! :D
Tim
Anything to do with toolchanges happens, or at least starts and ends in the M6 macros.
I'm not entirely sure, but I think once you've used M6start to move to your toolchange position, you can then use your tool zero button, then once you're finished and click cycle start again, M6end takes care of moving back to the work area.
m_c
Exactly. This is what I do on my own machine. All you need to do is put a move (in machine coordinates) to the touch plate location into the tool height set macro and the job's a good'un
Neale could you copy and paste what's inside your M06.M1S file please?
Regards,
Tim
Can do - will take a little time as I'll get the current copy off my machine. Might as well post m6start, m6end, and my tool-height setting routine while I'm at it. These all work, at least on my setup.
I have the auto tool zero function working.
Just struggling to set up the location, but that would all be fantastic.
Thankyou.
So, this doesn't do exactly what you need, but it might help a bit.
Attachment 23098
I suspect that what you need is something like:
code "g53 g0 x[your tool change X] y[your tool change Y]"
somewhere near the top of your tool height set macro. Note the G53 - this is important as it means "use coordinates on this line as machine, not work, coordinates"
Can you post your tool height set macro?
Neale
Attachment 23098
Hello Neale, I have sent you a email directly to you.
Regards,
Tim
Neale
Attachment 23098
AUTO TOOL ZERO SCRIPT:-
FeedCurrent = GetOemDRO(818) 'Get the current settings, OEM DROs (818)=Feedrate DRO
ZCurrent = GetOemDro(802) 'OEM DROs (802)=Z DRO
GageH = GetOEMDRO(1001) 'OEMDRO(1001)=Gage Block Height
ZNew = ZCurrent - 300 'probe down 20 mm
Code "G90F500" 'slow feed rate to 100 MM/MIN
Rem Code "G4 P1" 'Pause 1 second to give time to position probe plate
Code "G31 Z" &ZNew
While IsMoving()
Sleep(10)
Wend
Call SetDro (2,GageH) 'DRO(2)=Z DRO
FinalMove = GageH + 10
Code "G0 Z" &FinalMove
Code "F" &FeedCurrent 'restore starting feed rate dr.lin 2009.10.16
This thread can be closed now.
All resolved thanks to Mr Neale.
Thank you again for all your guidance.
Tim
Tim
Hi
I want to enable automatic tool change in Mach3 but I do not know how and where to start
Can you help me?
Personally, I would start with googling for "mach3 auto tool change macros"! That should give you some ideas.
BUT - every machine is different, so needs different macros. Do you have a carousel or tool rack? Fixed or moving rack? Auto draw bar - how is it controlled? What are the locking mechanisms on a carousel? And that's just for starters. What motion controller are you using? How many inputs/outputs? Does it have PLC capability?
This is non-trivial. Not necessarily difficult if you understand all the bits - mechanical, electronics, software - but a whole different ball game compared to the tool height setting macro that was the original topic.
Good luck...
