How much airflow needed for mist cooling setup???
With some cutting imminent (once I get the AXBB sorted!) I'm thinking I ought to get going on a cutter cooling/chip blowing setup. I have various air supply options available with varying degrees of noisyness, just wondering how much airflow is needed please? I'm thinkinh of making something a bit like Boyan's setup: thanks.
Re: How much airflow needed for mist cooling setup???
I think it will depend a lot on your setup. I find pushing around 3 PSI seems to work well enough for me, squirting air / ethanol mix.
Any idea how much volume you're using please (cfm or m3/hr)?? Adjusting the pressure is pretty easy, but if the compressor won't do the volume you're stuffed!
Nope. I moved to a screw compressor and a 200L tank setup so that I could compress and not be concerned about it.
OK, no worries, thanks for the info on the pressure - a lot less than I was guessing!
Ill double check but effectively my 'guess' is as much pressure as is need to help the lubricant but mostly to clear chips. Anymore feels like a waste.
I have done the same type of setup as boyan with the filter housing etc. Im running it at 15psi with thin cutting oil and that works well. I have an 8cfm compressor with 100 litre tank that keeps up fine. The thinner the cooling medium the less pressure you will need to move it.
2 Attachment(s)
johnsattuk
Complete control
Yes, I had forgot about that.
johnsattuk
Complete control
Yes John, I was thinking of doing something similar, I like the idea of having independent control of the fluid - and not having to buy an expensive pressurised contained for it!
Not pressurized , can be placed almost anywhere, 25ltr drum on the floor if you like
Voicecoil
just so you know this is what I am using in my system and as you can see its not expensive
https://www.ebay.co.uk/itm/10-in-lin...EAAOSw~vNcBnGQ
but I do like your complete system and if in had the time and ability I would build something like that
That's a good idea - much cheaper than anything I've seen from pneumatics suppliers. Even so the independent pump approach is better for me as it means I can use a wee side channel blower I have here for the air. It only does 5psi, but when I tried it a few minutes ago it scattered chips over 2m from the pillar drill :onthego:
