    With some cutting imminent (once I get the AXBB sorted!) I'm thinking I ought to get going on a cutter cooling/chip blowing setup. I have various air supply options available with varying degrees of noisyness, just wondering how much airflow is needed please? I'm thinkinh of making something a bit like Boyan's setup: thanks.
    Chaz's Avatar
    Lives in Ickenham, West London, United Kingdom. Last Activity: 4 Weeks Ago Has a total post count of 1,657. Received thanks 115 times, giving thanks to others 71 times.
    I think it will depend a lot on your setup. I find pushing around 3 PSI seems to work well enough for me, squirting air / ethanol mix.
    Any idea how much volume you're using please (cfm or m3/hr)?? Adjusting the pressure is pretty easy, but if the compressor won't do the volume you're stuffed!
    Chaz's Avatar
    Nope. I moved to a screw compressor and a 200L tank setup so that I could compress and not be concerned about it.
    OK, no worries, thanks for the info on the pressure - a lot less than I was guessing!
    Chaz's Avatar
    Ill double check but effectively my 'guess' is as much pressure as is need to help the lubricant but mostly to clear chips. Anymore feels like a waste.
    I have done the same type of setup as boyan with the filter housing etc. Im running it at 15psi with thin cutting oil and that works well. I have an 8cfm compressor with 100 litre tank that keeps up fine. The thinner the cooling medium the less pressure you will need to move it.
    Quote Originally Posted by johngoodrich View Post
    Thanks for that John, v.useful. 8cfm is not a lot, I won't need to use the big (and noisy) machine for that
    Complete control
Name:	Mister cool-1.jpg
ID:	27164   Click image for larger version.
Name:	Mister cool-2.jpg
    Lives in Marple Stockport, United Kingdom. Last Activity: 21 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 3,348. Received thanks 620 times, giving thanks to others 90 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    Quote Originally Posted by johnsattuk View Post
    Complete control
    Yes, I had forgot about that.
  1. Ethanol mist for cutting aluminium
    By matt-b2 in forum Swarf & Chip Management
    Last Post: 15-08-2021, 11:05 AM
  2. Mist Coolant Project
    By magicniner in forum Swarf & Chip Management
    Last Post: 06-11-2018, 09:39 PM
  3. Schneider Altivar 320 wiring / setup help needed
    By TadasM in forum Spindles & Drive Motors
    Last Post: 21-10-2016, 07:43 AM
  4. WANTED: Mist lubrication system
    By badgerman in forum Items Wanted
    Last Post: 21-08-2014, 12:28 AM
  5. i7 Water cooling system
    By Jonathan in forum Metalwork Project Showcase
    Last Post: 01-01-2012, 06:27 PM
