15 Attachment(s)
The remainder of the Zapp Automation Stock
I am selling the reminder of the stock from Zapp automation.
I have listed it on ebay, and this is the link.
https://www.ebay.co.uk/itm/324838124596
Its listed for £5000, so if you buy it outside of ebay, you can have a 10% discount if paid by bacs.
The stock was recently valued at around £65K and the stock includes the following, but there are other things there as well.
included are stepper motor, servo motors and drivers, ballscrew, ballnut, leadscrews, lead nuts, AC inverters, power supplies, Kanya Aluminium Extrusions and fixings, SYK ballscrew supports, motor mounts, boxes of belts and pulleys (HTD and T5) bearings, round linear shafting, planetary gearboxes, Pneumatic cylinders, solenoid valves and fixings & Tubing, lots of Lovato, switchgear, contactors and switches. Lot of acrylic offcuts and profile rail bearings.
there are lots of other parts that i have not mentioned and you are welcome to view .
due to the amount, this is pick up only, and you will require a large van or truck. Also the ballscrews, leadscrews and aluminium profiles are at least 3m long.
if you have any questions, please feel free to contact me.
I do not get notifications from this site, so if you are interested, please email me at [email protected]
If you have the time, you can sell this on eBay, but honestly, it's an opportunity to start your own little business or just use it to make a few machines.
I also have about £2k of aluminium tooling plate as well in 35mm,25mm, 15mm in various sizes. but that is separate at £500.
Attachment 30540
Attachment 30541
Attachment 30539
Attachment 30542
Attachment 30543
Attachment 30544
Attachment 30545
Attachment 30546
Attachment 30547
Attachment 30548
Attachment 30549
Attachment 30550
Attachment 30551
Attachment 30552
Attachment 30553
Re: The remainder of the Zapp Automation Stock
That tooling plate for £500 sounds like fun, but how would I get my sticky fingers on it?
Robin Hewitt
Hi Robin,
It would be a pallet rate or pick it up.
I can stick it all on a pallet and you can arrange the pickup, or i can look into getting a cost for you?
just email me directly with your address and i can look at it.
I think I have emailed you, I am getting a bit vague in my dotage.
Robin
Robin, not seen an email, also I have checked my spam.
Robin Hewitt
Robin
Robin,
When i get your email, i will get straight back to you.
Gary,
I have sent u a wee message on eBay.
Thanks,
Caesar
To: <[email protected]>
Subject: Aluminium tooling plate
Date: Tue, 19 Oct 2021 12:15:49 +0100
MIME-Version: 1.0
Subject: Aluminium
Date: Tue, 19 Oct 2021 16:39:02 +0100
MIME-Version: 1.0
'snot working :whistle:
Robin Hewitt
Robin,
Got your message now, will email you back later.
2 Attachment(s)
Robin,
these are the pictures showing all the aluminium plate, there are 15mm, 20mm, 25mm, 30mm and 35mm plate, and also a small amount of 10mm.
These are a few pictures showing how much there is.
I have put it all on one pallet, but will likely need to cut the 35mm piece to correctly fit the pallet width.
the 15 and 30mm pieces are about 1M square. the 35mm, is about 1.4M long. and the 25 is made up of a number of offcuts.
the 20 not fine milled.
Can you get back to me as soon as you can, because I need this gone quite quick.
As you can see its a good deal for £500.
a 1M by 1m piece of 30mm tooling plate from aluminiumwarehouse works out to be £1500, so well worth the £500 I want for it.
If you want me to send it, I will charge an extra £55 to deliver it by pallet.
Attachment 30572Attachment 30573
Robin Hewitt
Hi Gary
£550 delivered, no VAT added on and I get a receipt? :beer:
best
Robin
Hi Robin,
its £555 I am not vat registered and I am not a business, so can't give you an invoice.
Tricky, need a receipt or the revenue man will skin me :whistle:
battwell
did the aluminium sell?
Yes to Meeeeeee
