Massive mig welder hell to move
My Mig welder just arrived,its damn massive and the parcel blokey struggled to bring it out the van.
I'm double struggling to lift it outta the bladdy box :eek: ooh me back! ow.
Didn't think they were this big and heavy.
Post a pic later ifI manage to get it out,thank goodness its on wheels.
Re: Massive mig welder hell to move
Bet you couldn't lift it Lee,depite you size.:whistling:
Maybe I'm confusin the tip hitting the the earth and clogging thetip to the point it welds the wire to the copper tip?
http://www.screwfix.com/prods/30030/...IG-Welder-150A
I guess the only way to find out is to use the thing.:eek:
Just goes to show that ebay is not all that cheap in some respects.
Was lookin at the cheapest mild steel box section 25mmx25mmx3mm at £14 for 3mtrs plus £12 P&P so 6mtrs plus £12 =£40.
My local welders shop will do it at £25.60 includin VAT....sheeesh,its got to be a locality thing?
GeorgeD
Good idea.
One thing with these cheap welder they never tell you is about a thing called duty cycle.
Duty Cycle is how long you can use it at what setting. Look on the plate at the rear and it should give you some figures as a percentage.
The adverts says 150 amps but Screwflicks blurb says 140 amps for this model ?
So just guessing it will say something like 70 A @ 100%
90A at 80%
110A @ 60%
120A @ 40%
140A @20%
What this means is that the % figure is based on 10 minutes, so at 70A you can weld all day and at 140A it's weld 2 minutes, rest for 8.
For obvious reasons they don't make a big fuss of this. The more you pay the higher the figures.
Hi George,
Which part(s) of the machine are you thinking of using the 25mm box for? Might be a bit small, unless the machine is a little'un, or it is a space frame idea.
It is only a small version ie 850x600, the gantry height about 300mm to 350mm?
